Surging idle? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-23-2011, 03:07 AM Thread Starter
Surging idle?
I have a 97 rollback with surging idle hot or cold doesn't matter. Runs fine other wise. Any ideas where to start looking/checking would be great. I say it runs fine it doesn't miss or surge except at idle but does seem to be down on power don't drive the truck much just use to go pickup broke down work vans on occasion. So not real sure if it's down on power or just me because my daily driver is a hopped up 6.0.
WickedAddiction is offline
post #2 of 8 (permalink) Old 03-23-2011, 05:23 AM
blageurt's Avatar
Re: Surging idle?
Tin nut on the IPR tight ? Maybe you need an oil change ?
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #3 of 8 (permalink) Old 03-23-2011, 07:20 PM
Htownstroker's Avatar
Re: Surging idle?
Newb and just curious why he would need an oil change??
1997 F250 ccsb, e40d, 3.55, 2wd......first psd, gearhead tunes, isspro-boost, tranny, pyro, scan gauge 3" dp, 5" straight de, tymar, fpr shim, full energy suspension truck kit, 3.5 extra capacity tranny pan, super duty rear diff cover, 20" ion wheels....
Htownstroker is offline
post #4 of 8 (permalink) Old 03-23-2011, 07:21 PM
Re: Surging idle?
Also what's an ipr?
post #5 of 8 (permalink) Old 03-23-2011, 08:13 PM
Learner
94strokeher's Avatar
Re: Surging idle?
Had this same problem a few days ago. Found out the tin nut on my ipr was so loose! Snuged it up and problem solved, for now anyways. Hope that was all it was! The IPR is ( Injection Pressure Regulator ).
99 F250 Lariat 7.3 Auto, 6 inch Fabtech Lift, 35 KM2's, Straight pipe, 6637 intake.
94 Powerstroke, 3 inch lift, 3"DP 4" straight pipe 5" tip, Intake, Ts 6 position chip custom tunes. - SOLD
94strokeher is offline
post #6 of 8 (permalink) Old 03-23-2011, 08:39 PM
Re: Surging idle?
Thanks on the ipr but I'm really curious why he would need an oil change?
post #7 of 8 (permalink) Old 03-23-2011, 09:20 PM
zilla68's Avatar
Re: Surging idle?
the injectors are driven by oil, it breaks down over time, sometimes driveability issues are tied to the oil, that's why it comes up so much, so keep your oil fresh, changed, and clean.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #8 of 8 (permalink) Old 03-24-2011, 01:02 AM
Re: Surging idle?
Ok that makes sense...thanks guys
