armature plate adjusting screw - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-22-2011, 09:52 PM Thread Starter
ok how do i get this nintendo tool used to tighten the screw for injtor armature plate:
jtlease is offline
post #2 of 4 (permalink) Old 03-23-2011, 02:53 AM
Patrick Feeley's Avatar
Re: armature plate adjusting screw
You would have to search for one (its a #8, T25). We used to get them from Lara Specialty Tools, but can't seem to find them anymore. If it were me, I would remove them all (a ground-down 4mm socket will work) and replace them with socket-head cap screws from Mylex. Cheers!
Patrick Feeley is offline
post #3 of 4 (permalink) Old 03-23-2011, 02:56 AM
Dairy Mechanic
Magnum PD's Avatar
Welcome to PSN!!
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #4 of 4 (permalink) Old 03-23-2011, 01:08 PM Thread Starter
thanks for the help i will give that a try
jtlease is offline
