transmission problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-21-2011, 10:41 PM Thread Starter
My truck wont shift out of first. Once you get it to it shifts fine from then on. The only way to get it to shift is to run up to about 3500 rpm and then let out of the throttle and it will shift then it shifts good. Thanks in advance
powerchoke is offline
post #2 of 6 (permalink) Old 03-22-2011, 12:06 AM
Re: transmission problems
Auto or manual? Any mods? How many miles?
02 f250
countryboyrob is offline
post #3 of 6 (permalink) Old 03-22-2011, 04:23 AM Thread Starter
auto. its got injectors and has 350,000. it has had injectors for a year now and this just started all of a sudden.
post #4 of 6 (permalink) Old 03-22-2011, 09:46 PM
So no mods at all to the trans?
02 f250
post #5 of 6 (permalink) Old 03-23-2011, 02:54 AM
big nasty's Avatar
Sounds like 1st gear clutch. My 2nd gear clutch just took a crap and was doing the same thing, but just in 2nd gear. I am just going ahead and getting my trans rebuilt.
02 7.3 with a little of this and a little of that.
big nasty is offline
post #6 of 6 (permalink) Old 04-14-2011, 02:37 PM
used engines for sale
One of the most common misconceptions about rebuilding transmissions is that it will restore the transmission to a new condition, but this is definitely not true. Although it can help you restore the peak operating efficiency of the transmission, it is less effective in extending its lifespan. Rebuilding transmissions needs different parts of the transmission to be changed, making some of its parts older than or as old as the original parts.
I was in death valley on a geaology trip for college a few years back and we blew the rebuilt engines for sale. It was scary i will never buy a used transmissions again, because its basically just used but more expensive go figure.
lowerjon is offline
