No Start - 1995 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-21-2011, 03:58 PM Thread Starter
GM Duraturd's Avatar
No Start - 1995 7.3
Well my truck cranks and wont fire over. It is not getting any fuel because there is no smoke while cranking and no smell of exhaust.
In the shop there are 2 complete 7.3 motors sitting there so I had plenty of good parts to swap out and give it a try and still nothing.
What I have tried:
Fuel Filter
CPS
Removing Chip
PCM
IDM
Oil Pressure Sensor
All Fuses OK
The truck is getting 55psi of fuel pressure to the bowl while cranking. Any Ideas? IPR, ICP???
TOTALLED 1995 F-250
ISSPro, Grand Rock, DPP, DLC Diesel Performance, Total Diesel Performance, ATS, and a tired TTB.
1997 F-250
Precision Industries, Full Force Diesel, Beans Diesel Performance, DLC Diesel Performance, Banks Power, Aeromotive, Terminator Engineering, Gearhead Automotive, SuperLift, Bilstein, and a Dana 60
GM Duraturd is offline
post #2 of 13 (permalink) Old 03-21-2011, 07:49 PM Thread Starter
Re: No Start - 1995 7.3
bump... Im about to go throw another HPOP on it and see what that does? Anyone got any ideas.
Truck ran fine, never did anything abnormal at all, I parked it for about an hour and then went to fire it up and nothing...
TOTALLED 1995 F-250
1997 F-250
post #3 of 13 (permalink) Old 03-22-2011, 02:32 PM Thread Starter
Any Ideas?
TOTALLED 1995 F-250
1997 F-250
post #4 of 13 (permalink) Old 03-22-2011, 02:38 PM
USASF Retired
halo's Avatar
I'm kinda in the same situation as you...... My truck was running fine then lost power and quit running. Pulled the codes and low pressure injector error and cps failuler. Replaced the cps and cleared the codes, still will not start and system pass no codes.
I wonder if mt hpop is bad or an injector it stuck open causing the hpop to make no pressure.
1996 F-350 Crewcab 4x4 7.3 PSD E4OD
"The pacifists always lose, because the anti-pacifists kill them." - Raymond S. Kraft
"The true soldier fights not because he hates what is in front of him, but
because he loves what is behind him." -G. K. Chesterton
halo is offline
post #5 of 13 (permalink) Old 03-22-2011, 03:30 PM
TBarrsTruck's Avatar
Def try the ipr first before the hpop, but before those try checking to make sure the hpop reservoir is full by removing the brass plug on top, should have oil up to the top or dang close. Also search for this topic on here you'll find a ton of stuff to check.
'97 4x4 ECLB: SD IC, TW 4 pos, afe, 3-4" w/areoturbine, 4 gauge, DIY stage 1s, GTP38R, cust E-fuel, E-brake, stage3 CM meth, 439hp still trying for 600. cust stereo, highamp alt, cust paint
'78 F-150 RCLB: 460 swap, 3" lift, 33's,Trussed 9" w/ chrome-moly shafts, cust stereo, locked front/rear. My first love! EFI & Turbo coming soon...
TBarrsTruck is offline
post #6 of 13 (permalink) Old 03-22-2011, 03:33 PM
< Can I drive?!
wint's Avatar
Double check your oil level. Coming out of the winter i know our trucks are always low on oil. Good luck man.
The Army wants you!
wint is offline
post #7 of 13 (permalink) Old 03-22-2011, 08:05 PM Thread Starter
Tried it... reservoir 3/4 full
Checked about 3 times
TOTALLED 1995 F-250
1997 F-250
post #8 of 13 (permalink) Old 03-22-2011, 08:07 PM Thread Starter
I never lost power, but for you it sounds like it could be a HPOP. I got no codes.
My HPOP makes approx 420psi while cranking and about 3700psi while cranking with the IPR unplugged, which I believe is fine.
TOTALLED 1995 F-250
1997 F-250
post #9 of 13 (permalink) Old 03-22-2011, 08:10 PM
Terminator Nation
Check the IPR mounting nut for tightness and harness for bare spots. Also swap out the ICP sensor. Then try IPR itself.
old man dave is offline
post #10 of 13 (permalink) Old 03-22-2011, 08:10 PM
Harl
Harl's Avatar
Send a message via AIM to Harl
Does it act like its out of fuel when cranking? Or does it even sound like the injectors are fireing?
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
