leaking banjo bolt indicate bigger problems? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-21-2011, 08:06 AM Thread Starter
washingtoncoastie's Avatar
I've been told by a few people that when the banjo bolt starts leaking it is time for a new pump. buddy of mine that is a ford tech said that ford designed it that way to kinda work as an indicator that the fuel pump is on the way out. mine started leaking a few days ago and when i looked at it, it was pretty loose and i tightened it back down. so is my buddy right? is it time for a new pump? i would like to go over to electric fuel but i dont have the funds considering that just last week I put in new warn hubs, gp's, gpr, uvcwh, tie rods, brakes, rotors, and wheel studs. i am moving to alaska in a few months and dont want to end up on the side of the road because i failed to diagnose a problem right. thanks again for the help guys!
washingtoncoastie is offline
post #2 of 5 (permalink) Old 03-21-2011, 07:36 PM Thread Starter
Re: leaking banjo bolt indicate bigger problems?
No one?
post #3 of 5 (permalink) Old 03-21-2011, 07:39 PM
strokefreak
strokefreak's Avatar
depends really. i drove mine around for months with it leaking from the weephole on the pump. its only about 100 bucks if i recall. but i was told the same thing about it. leakage from weephole indicates a bad diaphram and possible pump failure. yadda yadda. you can get the parts and replace it "fairly" easily. luck!
1996 Powerstroke. 159000 miles.
Custom F-250 Duallie Conversion.
Tymar - gauges - Swamps Tunes - MBRP Turbo back exh. Swamps HiFreq/HiVol IDM. Full Force Stage 1's. WW2. T500. SOLD.
2003 CCLB F-350
Current toy / exploder.
strokefreak is offline
post #4 of 5 (permalink) Old 03-22-2011, 07:45 AM
mmm if it was the banjo that was loose and you did it up I would mop up any residual fuel and see if the fuel pump is leaking too. your buddy the mechanic I think is speaking about the weep hole on the pump if it leaks then yes you need a fuel pump. These are two separate issues.
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #5 of 5 (permalink) Old 03-22-2011, 09:01 AM
Boost Gets You Laid
jrc
Correct!
1997 F-350 7.3L
Hypermax Intercooler, DIY intake, RDS Stage 2s, Bob Rileys(CPR fuel system, HPOP Crossover, Coolant Filter) SouthBend Dual Disc clutch, TW custom tunes, Farmboys full 4", 17* HPOP,
1997 Jeep Cherokee
2004 Land Rover Discovery
1985 Mercedes 300 Turbo Diesel
2001 Sterling Silver Star
2005 Volvo VNT64T660
RCPro87 is offline
