F350 Stock Block Height - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-21-2011, 04:24 AM Thread Starter
I have purchased some F350 front springs, but I'm not sure what size blocks to get for the rear to get a level height. I've read where it can be either 2" or 3". Can anyone help me out?
Thanks,
Scott
'97 F250 CC SB - Dana 60 Swap, 4.10s, Tymar intake, 3" DP, 5" Diamond Eye straight pipe, ISSPRO Gauges (Boost, Pyro, Trans), Tru-Cool Max trans cooler, Swamps IDM
TacticalMonk is offline
post #2 of 9 (permalink) Old 03-21-2011, 05:10 AM
JFURNER77
JFURNER77's Avatar
Re: F350 Stock Block Height
What exactly are you trying to achieve with your suspension?? It will also depend on what you have for rear springs.
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 390,000
T/S 6 POS CHIP, STAGE 1'S, 17* HPOP
6637 AIR INTAKE/NO CAT
4R100 STAGE 3- 12" TRIPLE DISC BILLET TORQ, BILLET INPUT, RED ALTO'S, TUGGER KIT, CUSTOM VALVE BODY, DERALE TURBO PAN.
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
JFURNER77 is offline
post #3 of 9 (permalink) Old 03-21-2011, 05:15 AM Thread Starter
I have stock f250 springs. I'm not trying to lift the rear too much, but have a level truck when I install the f350 springs in the front.
Scott
post #4 of 9 (permalink) Old 03-21-2011, 05:03 PM
STILL LEARNING
Bradbilt's Avatar
A stock F350 rear block is 4"
Bradbilt is offline
post #5 of 9 (permalink) Old 03-21-2011, 05:16 PM Thread Starter
Thanks. I appreciate your help.
Scott
post #6 of 9 (permalink) Old 03-22-2011, 02:49 AM
96P_Stroke4x4's Avatar
on my truck, i kept the stock 2" f-250 blocks in the rear when i did the dana 60 and front f-350 spring conversion. my truck sits almost level now
'96 F-250 XLT,x-cab,4x4,BTS,363k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust,twin 6" stacks,Tymar, Boost Pyro Tranny and white-faced gauges,I/C,onboard air,HX mod,TW 6-position chip
96P_Stroke4x4 is offline
post #7 of 9 (permalink) Old 03-23-2011, 06:41 PM
DIRT NASTY DIESEL!!
~NASTYSTROKER96~'s Avatar
if your puttin f350 springs in the front of your truck and your runnin the TTB its not a good idea, i dont think them springs are designed for the twist that the axle produces and could cause issues, better off just doin add a leafs or put a Dana 60 under it
Michael ~96 Ford F250~
Diamond eye exhaust, Autometer Ultralite gauges, Rough Country leveling kit, Superchip Programmer
~NASTYSTROKER96~ is offline
post #8 of 9 (permalink) Old 03-23-2011, 06:45 PM
STILL LEARNING
Bradbilt's Avatar
I reread your post and you didnt mention anything about a D60. F350 springs are NO GOOD for a TTB suspension
Bradbilt is offline
post #9 of 9 (permalink) Old 03-23-2011, 06:49 PM Thread Starter
You are correct. I forgot to mention that I'm putting a D60 under it at the same time. I don't have the money to do the RSK right now so I'm just trying to do the part I can, while I can.
Thanks,
Scott
