cant find oil leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 03-21-2011, 04:16 AM Thread Starter
ford7.3diesel
cant find oil leak
i have a 1997 ford f250 7.3 just this morning i went out side an saw a puddle of oil on the ground on both side of the motor and one smaller one in the front the valley is full of oil and it leaks really bad and a steady drip when off dont know were exactly it leaking from to fill the vally but truck runs fine and my oil pressure is were its suppsoe to be was wondering what it could be please help any info would be great
ford7.3diesel is offline
post #2 of 14 (permalink) Old 03-21-2011, 04:26 AM
Keep er shinny side up!
Re: cant find oil leak
Best place to start would be to clean up the top of the motor and get a good light. If it's leaking that bad you should be able to pinpoint it once its cleaned up. Could very well be coming from the HPOP, or the lines.
abbottfarms is offline
post #3 of 14 (permalink) Old 03-21-2011, 04:36 AM
salprofish's Avatar
I had a bad oil leak and it was the oil rail plug, now I know that something else is probably leaking if you have oil in the valley, ( hpop, or lines)
But it wouldnt hurt to check the oil rail plugs.
Real Bad Oil Leak- Need Some Advice - PowerStrokeNation
97 250 EC 4x4
5 speed
6637 Napa Filter
ccv mod
3" diamond eye dp
175cc 80% over Rosewood inj.
Custom tuning by Cale Thompson
4" Rough Country Lift
315-70-17 BFG AT Tires
Rebuilt zf5 at 250000
my new favorite gun:
LAR grizzly 50 BMG big boar
salprofish is offline
post #4 of 14 (permalink) Old 03-21-2011, 04:50 AM Thread Starter
ford7.3diesel
im gonna clean it out tomorrow with greae lightnig and a pressure washer ill keep you up dated
and were are the plugs located are those the same as the oil galley plugs
post #5 of 14 (permalink) Old 03-21-2011, 04:53 AM
salprofish's Avatar
Check out the link, I did a writeup on it.
97 250 EC 4x4
5 speed
6637 Napa Filter
ccv mod
3" diamond eye dp
post #6 of 14 (permalink) Old 03-21-2011, 05:00 AM
JFURNER77
JFURNER77's Avatar
The oil rail plugs are in the rear of the cylinder heads. You will have to remove your down-pipe to replace the passenger side. There is an updated plug available through Ford with new o-ring design. Get the engine cleaned up, and get some light on it. Check Hpop & lines, use a mirror to check the oil rail plugs. Good luck
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 390,000
T/S 6 POS CHIP, STAGE 1'S, 17* HPOP
6637 AIR INTAKE/NO CAT
4R100 STAGE 3- 12" TRIPLE DISC BILLET TORQ, BILLET INPUT, RED ALTO'S, TUGGER KIT, CUSTOM VALVE BODY, DERALE TURBO PAN.
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
JFURNER77 is offline
post #7 of 14 (permalink) Old 03-21-2011, 05:16 AM
salprofish's Avatar
Im pretty sure they are on the front too.
97 250 EC 4x4
5 speed
6637 Napa Filter
ccv mod
3" diamond eye dp
post #8 of 14 (permalink) Old 03-21-2011, 02:42 PM
OBS Addict
7.3psd97444's Avatar
Yeah mine was on the front. It leaked real bad and I got the new one from ford and it's fine now. Just had to remove the alternator and mounting to get to it.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #9 of 14 (permalink) Old 03-21-2011, 05:00 PM Thread Starter
ford7.3diesel
i check those an there fine which i guess is a pluss but now i got to find it i was suppose to clean it but its snowing here what a way to bring in spring
post #10 of 14 (permalink) Old 03-22-2011, 12:30 AM
JFURNER77
JFURNER77's Avatar
That is correct. I guess what I was trying to say was, the ones in the rear are harder to check for leaks. It should be no problem to see if the front plugs are leaking.
