Trans Temps - Analog Gauge VS Edge CTS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-20-2011, 04:23 AM Thread Starter
Moderator
PsRumors's Avatar
I am almost certain I read somewhere that the trans temp on an analog gauge differs from that of the Edge CTS and other scanners due to where the sending units are located.
Is there a difference and if so how much?
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #2 of 3 (permalink) Old 03-20-2011, 04:40 AM
OEM Moderator
Tom S's Avatar
Re: Trans Temps - Analog Gauge VS Edge CTS
I have also read those posts and observed this. Expect like 10 degrees hotter on a scan kind of gauge.
Tom S is offline
post #3 of 3 (permalink) Old 03-20-2011, 05:27 AM
Demon Dually
speeddemon31176's Avatar
An analog gauge sending unit is usually mounted in a pressure test port up away from the pan. The factory sending unit is located on the solenoid pack. Yes there will be around a 10 degree difference in temps.
speeddemon31176 is offline
