To M/T or not... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-19-2011, 10:14 PM Thread Starter
To M/T or not...
Just pulled the tranny out of my 97, found that the flywheel was broken out of the center like I thought it was. It must have run like that for a while, because the edge of the crankshaft at the break was worn down. I have a new A/T flywheel to put back in it, and I also have a full ZF5 setup I can put in. Do I dare run the A/T flywheel with the outer edge worn down like that? I'm fairly sure if I went with the much thicker M/T flywheel I would have no issues in any event. Of course it's a lot more work that way too...
If anyone needs pics, I can get one.
Thanks
1997 F350 CCLB Dually XLT
1986 Bronco 6.9 Turbo XLT
Powertrain engineer by trade have worked for three OEM's.
86turbodsl is offline
post #2 of 6 (permalink) Old 03-20-2011, 05:19 AM
Demon Dually
speeddemon31176's Avatar
Re: To M/T or not...
Post a pic of the "damage" and it can better be determined if you will have an issue running the auto flexplate.
speeddemon31176 is offline
post #3 of 6 (permalink) Old 03-20-2011, 01:35 PM Thread Starter
Ok, here you go.
post #4 of 6 (permalink) Old 03-22-2011, 04:33 PM Thread Starter
bump
post #5 of 6 (permalink) Old 03-24-2011, 06:52 AM
CATnappin's Avatar
86turbodsl; My E4OD just went out the other day, would you be interested in selling that ZF5 setup tht you have?
1997 Ford F 250
built automatic with 4.10's
Diamond Eye down pipe, straight piped
Baby Swamps injectors
TS 6 position chip with custom tunes
K&N cold air intake
3 gauge pillar pod (trans, pyro, boost)
2.5 inch Tuff Country suspension lift
16x8 Mickry thompson Classic II's
33x12.50's
CATnappin is offline
post #6 of 6 (permalink) Old 03-24-2011, 11:30 PM Thread Starter
Not really, my long term plan is to put the drivetrain w/zf in the 86 F250 I have from Texas. The 97 is pretty rusty. I'm just trying to keep it rolling while i pay off debt. but thanks for asking.
