Engine died at 60mph - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 03-19-2011, 07:42 PM Thread Starter
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
Last night driving on the highway an my trucks engine shut itself off at 60mph... Then wouldnt start up again, the batteries didnt have enough juice to turn the truck over. Got a guy to come give me a jump, before then i took the terminals off an cleaned them then hooked up the chevy and let him charge the batteries.
To prepare for trying to start up the truck, i primed my fuel filter, switched tanks and broke out the John Deere ether....
Needless to say the truck wouldnt turn over... It tried super hard but it couldnt "light off"...
Any thoughts on what the hell the problem is??
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #2 of 39 (permalink) Old 03-19-2011, 09:37 PM
Krause's Avatar
Re: Engine died at 60mph
Could be the alternator. The truck needs electrical signal to run, without the alternator, the truck would have run off the batts until the bitter end when they finally didnt have any juice left. Without the IDM firing the injectors it wont start/run. I had this happen to me in the middle of the night driving across the country. Had to have it towed to the nearest town, then changed the alternator in the NAPA parking lot. A boost from a local (it took a while, 1 bat wouldnt do it we had to wait for his to charge mine a bit) and I was off to the races.
Krause
96 XLT ECLB. 6.0 intercooler. 4" aero turbine, gearhead tunes. Coolant filter & CCV mod. SD Dana 60 3.73 3.5 RSK V-codes, 35 inch toyos, 18inch M/T classic locks. 260000Km
Krause is offline
post #3 of 39 (permalink) Old 03-20-2011, 01:44 AM Thread Starter
Underfunded
moonshiner's Avatar
What are my options for an upgrade of the stock unit? If there are any??
2010 VW Jetta 2.5
post #4 of 39 (permalink) Old 03-20-2011, 05:24 AM
Demon Dually
speeddemon31176's Avatar
Alternator wise? There are several options. DB Electrical has a few different amperage options. Powermaster has a couple as well. Even factory options up to and including going with the dual alternator setup.
speeddemon31176 is offline
post #5 of 39 (permalink) Old 03-20-2011, 07:57 PM Thread Starter
Underfunded
moonshiner's Avatar
Could this be a cam position sensor issue??
2010 VW Jetta 2.5
post #6 of 39 (permalink) Old 03-20-2011, 08:00 PM
bluedge8's Avatar
to clarify, you are saying the starter wouldn't spin the engine over? or the truck turned over but the engine never fired?
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #7 of 39 (permalink) Old 03-20-2011, 08:01 PM
If it was barely cranking over I would say that your starter was going out cause a big draw on the batteries, then in turn caused the alternator to work hard to keep the batteries charged but couldnt keep up and failed. Leaving you to drive along on battery power till they finally died.
Thats just my guess.
02 f250
countryboyrob is offline
post #8 of 39 (permalink) Old 03-22-2011, 01:54 AM Thread Starter
Underfunded
moonshiner's Avatar
Starter works fine. Its turning the engine over, but truck isn't firing up i.e. Running on its own. Changed brushes in alternator and still wouldnt start up.
2010 VW Jetta 2.5
post #9 of 39 (permalink) Old 03-22-2011, 01:57 AM
Is it turning over fast or no? Is it showing anything on the tach?
02 f250
post #10 of 39 (permalink) Old 03-22-2011, 02:06 AM
bluedge8's Avatar
ok, so are the batteries fully charged? any fluid leaks?
bluedge8 is offline
