Wheels - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-19-2011, 05:00 PM Thread Starter
Wheels
I am thinking again and what a dangerous thing this is. Compareing the obs wheels -6.5 - circle and the sd wheels 170.0 mm circle. 6.5 inch = 165.1 mm. 170. mm = 6.6929133858 inch.. If I do the math I think this means the 170 is .0254 or 30 thousanths larger than 6.5. Am I thinking correctly that If using a milling maching, I can move the center of the lug hole .015 to the outside and not increase the diameter of stud (just remove material in the one direction). H as anyone considered this? Is it possible and will it work. I guess I need some other opinions on this. ????????????
foxman is offline
post #2 of 6 (permalink) Old 03-19-2011, 10:24 PM
PowerStroke Fan
patrick66's Avatar
Re: Wheels
NO! The lug nut needs to seat perfectly 360 degrees around each lug hole in the wheel. If you machine these larger, you'll have oblong bolt holes in the wheel, and the nut having a firm seat on only one-half of each of the lug holes. This WILL stress the wheel to the point of fracture and failure.
And, if you attempt to use the wheel as-is on the truck, you will watch your wheels and tires come off in a matter of a few miles. Thirty-thousandths doesn't sound like much, but here, it most definitely IS. Think about that .030"...that is the gap on most spark plugs!
Get the right wheel and run with it.
1995 F350 SRW XLT 4x4 LB CC
patrick66 is offline
post #3 of 6 (permalink) Old 03-20-2011, 04:49 PM Thread Starter
Re: Wheels
I do understand exactly what you are trying to say However if you remove one lugnut on the 250 0r the 350 you will notice more than .030 space around the stud. These trucks use a hub-piliot and the lug nuts have built in washers. I understand what you are saying and if these trucks had the tapered seat on lug nuts and were centered by the nuts themselves then you wdould be correct. Please take one nut off your truck and let me know what you think???
Foxman
foxman is offline
post #4 of 6 (permalink) Old 03-23-2011, 11:08 AM
RubberDuck
Re: Wheels
I was at Barnes and Noble the other day and read in one of the current diesel mag's that as a side note in the article that the rims were from a Sd had been machined to fit an OBS. I believe the article was focused on tire test. Sorry don't remember which mag had it.
Frank
97 F350 4x4 4.10 Crewcab, 3" down pipe, 4" mag flow, tranny cooler and shift kit, Mile Marker hubs, tymar intake, tymar coolant filter, tymar oil crossover, Browns front bumper, side steps and headache rack, ranch hand rear bumper.
fcjarrett is offline
post #5 of 6 (permalink) Old 03-23-2011, 11:27 AM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Re: Wheels
I've got some wheels and tires I will sell you
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #6 of 6 (permalink) Old 03-24-2011, 01:30 AM
Re: Wheels
I saw where a guy took excursion rims machined them to fit obs pattern and installed steel insert cups. Think that was on here a while back though. If you got rims for next to nothing and found a machine shop that would do the work and if the inserts where resonably priced might work. You just might be better off buying the right pattern is what I discovered.... But it can be done
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
