intenational water pump with coolant filter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-19-2011, 12:00 AM Thread Starter
radcustoms's Avatar
ran into a little problem am doing the international water pump with coolant filter mod on my 97 psd. I got a t- stat for the orignal pump but thats not the right one its to long for the new housing. I am guessig i need one from international for that pump but they are closed now and i really need my truck done for the morning. Or can i run one off the self from like pepboys if so would anyone know the brand and part number.
95 F-250 4x4 standard cab, under construction PULLER
97 F-250 4x4 ex. cab short bed. Daily driver
radcustoms is offline
post #2 of 2 (permalink) Old 03-19-2011, 03:13 AM
Patrick Feeley's Avatar
Re: intenational water pump with coolant filter
You need the short one from a 94.5 or a 95 (and they come in 203F too). For example: "Thermostat"
Cheers!
Patrick Feeley is offline
