7.3 boring ?s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 03-18-2011, 05:39 PM Thread Starter
swamp_ratt's Avatar
7.3 boring ?s
i pulled my motor a few nights ago and tore it down to the short block after a no oil pressure issue (build time, or so i thought) and i can fit my driver license between the cylinder wall and piston EASILY! id say shes rather egg shapped. my question is this... what is the safest you can over bore a 7.3 to handle 350/200s, a stage 1.5 cam and 38r/gt47 compounds with some hot tuning? can it be sleeved to handle it reliably? or should i say eff the sleeving price and find a new block for the same price as sleeving if it cant safely be bored? with the above mentioned mods, it will be beat on. keep that in mind
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #2 of 16 (permalink) Old 03-18-2011, 09:08 PM
Re: 7.3 boring ?s
Most bore .20 over or .30 I went with .20 with Mahle pistons but I'm not running injectors as big
1995 Ford F250 4X4 Sup cab Long bed off white
7.3L Powerstroke, 5 speed manual
Mods Stancor GPR, Diamond eye 3" DP, Diamond Eye 4" Exhaust, AFE Stage II,
Banks 5" Tips,Dana 60 Swap,Electric Fuel System,Swamps IDM,Adrenaline HPOP,AutoMeter Boost,Pyro,Fuel Pressure arp head and main studs,d66 turbo,
stage 1 injectors,6.0 intercooler
Rantheman is offline
post #3 of 16 (permalink) Old 03-20-2011, 02:44 AM
lincolnlocker's Avatar
Re: 7.3 boring ?s
how'd everything come out?
00,f350 lariat,4x4,cc,drw,38r,bdp stage 2/170cc/100s,bdp live tunes,4''down 5''back,dieselsite adrenaline,diy RR w/walbro,bellowed uppies, BTS trans!
01, rclb, 4x4, zf6, caned ts tunes, xl work truck package, 4'' tbe
lincolnlocker is offline
post #4 of 16 (permalink) Old 03-20-2011, 07:08 PM Thread Starter
swamp_ratt's Avatar
Re: 7.3 boring ?s
Well I talked to my machinist and he filled me in that the top of the piston is smaller (bigger gap from the walls) than the bottom of the piston for heat expansion. So with that being said I feel more relieved and my motor will be going to him as soon as I pick out my pistons
post #5 of 16 (permalink) Old 03-21-2011, 01:50 PM
Re: 7.3 boring ?s
Sweet!!
post #6 of 16 (permalink) Old 03-21-2011, 02:05 PM
OBS finding my way
jake2far's Avatar
Re: 7.3 boring ?s
I would send your block in first, have the machist find out how much needs to be bored out then buy your pistons. 2 dimension checks need to be made, 1 how much over size on the bore do you need to clean up the holes, pistons are available .010-.040. Your block can handle any of these pistons. 2 if the block needs to be decked the piston protrusion above the block needs to be checked, .010 shorter pistons are available to allow for a lower deck. Find out what your block needs before you buy the pistons or make sure they will take them back if you need a different piston size or height.
Good luck on your build.
Jim
1996 OBS Crewcab, Shortbed, 4x4, Automatic Transmission, Baby Swamps, Adrenaline HPOP, SuperDuty Electric Fuel Pump conversion, Quick Turbo Housing, 6 Position Chip, 3" Down Pipe, 2 Disc Locking Converter, Intercooler
jake2far is offline
post #7 of 16 (permalink) Old 03-22-2011, 03:06 AM Thread Starter
swamp_ratt's Avatar
Re: 7.3 boring ?s
Yeah that's kind of the way I was going to do it. Just gotta have the pistons ready to be sent to me at a moments notice when my machinist gets to my motor. He's backed up about 2.5 months right now but I don't plan on being able to drive my truck till the end of the year at the earliest
post #8 of 16 (permalink) Old 03-22-2011, 06:00 AM
Re: 7.3 boring ?s
83 Ranger 2wd, 2.2 perkins 4cyl diesel, 4sp-all stock
95 F-350 4X4, 7.3, auto, reg cab longbox- 4'' MBRP exhaust, 6637 intake, T-500, intercooler, gauges, fluidamper, FS-2500, swamp's modded idm, '03SD seats and more to come...
**WANTED** 4spd transmission for a diesel ranger with 2.2 perkins diesel..pm me if you have one..
predator86 is offline
post #9 of 16 (permalink) Old 03-30-2011, 03:47 PM
Re: 7.3 boring ?s
What did ya figure out? U starting with a different motor er what?
post #10 of 16 (permalink) Old 03-31-2011, 08:07 PM Thread Starter
swamp_ratt's Avatar
Re: 7.3 boring ?s
i dont have money to do nothin right now, but i will find out when i can. my focus right now is body work and paint cuz thats the cheapest. the motor will take a bit yet. probably next month ill be ready to get it in. but my machine shop is 2.5 months behind right now
