08 console power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-18-2011, 03:03 AM Thread Starter
pmasterson's Avatar
08 console power
Just installed an 08 console and SD seats (super comfort upgrade). The console has 2 accessory plugs. Can I just splice into the factory accessory plug wires and run them to the console or should I run a separate power from the fusebox and ground it to the firewall? Forgive me - I am electrically challenged. How did those of you that have an 08 console run power to it? Anyone know where/part # of the matching connector to the 08 oem console connector?
1995 F350 CCLB 4X4
TW tunes, GS gauges, Aeroforce Interceptor
3" RSK w/SD springs & Bilsteins
DIY 6637, 3" DP to straight exhaust
pmasterson is offline
post #2 of 8 (permalink) Old 03-18-2011, 03:07 AM
Demon Dually
speeddemon31176's Avatar
Re: 08 console power
You can get the matching connector at any parts store in the electrical isle. I just tapped into the power and ground for the lumbar support motor. Plenty of power available there.
speeddemon31176 is offline
post #3 of 8 (permalink) Old 03-18-2011, 03:40 AM Thread Starter
pmasterson's Avatar
I had considered that coz that connector is just laying under the seat. Would be real handy. Do you know off hand if that is powered with key off? I like to be able to leave electrical gadgets charging in the truck even when it is off which is why I considered the factory power plug harness.
1995 F350 CCLB 4X4
post #4 of 8 (permalink) Old 03-18-2011, 03:59 AM
I make smut cry
It is a constant 12v
Powerstroked162 is offline
post #5 of 8 (permalink) Old 03-18-2011, 05:10 AM Thread Starter
pmasterson's Avatar
Great. Makes it much easier. Thanks Guys.
1995 F350 CCLB 4X4
post #6 of 8 (permalink) Old 03-18-2011, 05:45 AM
Krause's Avatar
And pics or it didnt happen
96 XLT ECLB. 6.0 intercooler. 4" aero turbine, gearhead tunes. Coolant filter & CCV mod. SD Dana 60 3.73 3.5 RSK V-codes, 35 inch toyos, 18inch M/T classic locks. 260000Km
Krause is offline
post #7 of 8 (permalink) Old 03-18-2011, 06:02 AM Thread Starter
pmasterson's Avatar
. Pics tomorrow? Gotta finish putting the interior back together.
1995 F350 CCLB 4X4
post #8 of 8 (permalink) Old 03-19-2011, 12:00 AM Thread Starter
pmasterson's Avatar
BTW - does anybody know a part # for the oem matching connector to plug into the console harness?
OK Krause. Here's the proof. I know. I know. I like posts better with pics also. These are not real good quality coz I was too lazy to go get the real digi camera but.....they're better than a sharp stick in the eye.
Picked up front and back leather Lariat seats for $300 coz the drivers seat had a permanent stain from a tire that was sitting on it for no telling how long. Tried several chemicals to remove the stains but no luck so I tried colorbond on the drivers seat. Came out so good I did the rest of the seats, dash pad, arm rests and door padding.
Before:
After Colorbond Med. Prairie Tan:
08 SD console. I have about 1/16" clearance between the armrests and the console. Haven't actually used the armrests since installing the console. Still trying to decide what color I want it. Thinking matching tan on top and sides and matching blue on front and back or vice versa.
Also, while I had the seats out I installed Fatmax Rattletrap soundproofing and did the weatherstrip mod with 3/8" OD surgical tubing. Weatherstrip mod made a huge difference in blocking road and wind noise. Injector clatter still loud though. Didn't do the firewall or hood.......yet.
1995 F350 CCLB 4X4
