Diagnostic code help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-17-2011, 12:45 PM Thread Starter
Rmartin-97's Avatar
Po344
Po603
2009 f-250 dpf deleted kem tuned
1997 f-250 438hp 778tq sold
Rmartin-97 is offline
post #2 of 6 (permalink) Old 03-17-2011, 01:16 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: Diagnostic code help
P0344 = Cam Position sensor
P0603 = Keep alive memory
Is it a no start?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 6 (permalink) Old 03-17-2011, 01:49 PM Thread Starter
Rmartin-97's Avatar
No it starts and runs I just have a rough idle do I news a cam sensor?
post #4 of 6 (permalink) Old 03-17-2011, 02:10 PM
Fixing Broken Stuff
Well, i have not seen a CPS cause a rough idle, but I have read a few threads about driveabilty problems caused by a bad CPS. I think there are a few different color CPS's that have been available and I'm not sure which one is best, if you search the site you should be able to find some threads about it or just wait someone else will chime in. A new CPS from the dealer is only about $25 .
2004 Jetta TDI
1956 F100
post #5 of 6 (permalink) Old 03-17-2011, 02:12 PM Thread Starter
Rmartin-97's Avatar
What does the other code mean
post #6 of 6 (permalink) Old 03-17-2011, 08:34 PM
Demon Dually
speeddemon31176's Avatar
The 603 code comes up if you have disconnected the batteries recently. The CPS can and will cause a rough idle if it is bad.
speeddemon31176 is offline
