Split Second, No Power! What The...? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-17-2011, 02:21 AM Thread Starter
Okay guys, here's the problem: Three times in the last month, my truck just turns off, for a split second, and then all is fine. This has happened twice, while getting onto the freeway, and once, while on the freeway. I'm thinking the problem is electrical, as the last time it happened, it was a little longer pause. About a second, maybe. I did notice that the tach dropped about 1000 RPM's, but my truck is a manual trans, so in reality, the R's would have really not dropped at all(almost). The tach dropping, is what's making me think it's electrical. Anyone have any ideas? Maybe it's happened to one of you? I want to get this resolved asap! Summer's coming, I'll be pulling a trailer, and I don't want to be dead in the water somewhere! Thanks guys!
OBS96 is offline
post #2 of 7 (permalink) Old 03-17-2011, 02:23 AM
Re: Split Second, No Power! What The...?
CPS
02 f250
countryboyrob is offline
post #3 of 7 (permalink) Old 03-17-2011, 02:24 AM
Mine does this same thing. Its always at slow speeds and when i'm accelerating. It will cut out for just a split second, But it does it maybe once a month. It actually did it today, and the last time i can remember was late January/early February. It just cuts out for a second, but runs great the rest of the time.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 215k miles: FFD 250/200%'s, Swamps IDM, built trans, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube, Homemade e-fuel/intake/exhaust/traction bars, D66, Built and tuned by me
97 ECSB F-250 project truck. Current plans: 7.3, BTS, 250/2's, 468, stock bottom end
JD3020 is offline
post #4 of 7 (permalink) Old 03-17-2011, 07:51 AM
Demon Dually
speeddemon31176's Avatar
That is classic CPS symptoms like Rob said.
speeddemon31176 is offline
post #5 of 7 (permalink) Old 03-17-2011, 02:05 PM
Must be the lovely gray sensor then. My truck did it when i first got, then i was chasing what turned out to be a ICP sensor problem, and i put in a new gray CPS and it still does it.
Jimmy
JD3020 is offline
post #6 of 7 (permalink) Old 03-17-2011, 02:27 PM
salprofish's Avatar
Mine did the same thing, CPS for sure.
97 250 EC 4x4
5 speed
6637 Napa Filter
ccv mod
3" diamond eye dp
175cc 80% over Rosewood inj.
Custom tuning by Cale Thompson
4" Rough Country Lift
315-70-17 BFG AT Tires
Rebuilt zf5 at 250000
my new favorite gun:
LAR grizzly 50 BMG big boar
salprofish is offline
post #7 of 7 (permalink) Old 03-17-2011, 10:56 PM Thread Starter
Looks like I'll be changing a CPS then. At least it's an easy fix! Thanks Guys!
OBS96 is offline
