Turbo screaming HELP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-17-2011, 01:24 AM Thread Starter
mroutlawoffroad
OUTLAW-OFFROAD's Avatar
Got my truck out today an turbo sounds like its screaming. Not only that, its only building about 17 psi of boost, it usually builds around 28 psi. If I stay WOT for more then 5 seconds the check engine light comes on. I looked at my turbo wheel its not good shape evey fin has a small chip missing from the corner. I wish I knew how to post pics I would show the wheel. Any help would be great guys.
OUTLAW-OFFROAD is offline
post #2 of 9 (permalink) Old 03-17-2011, 01:27 AM
Re: Turbo screaming HELP
think you already solved your issue lol freshen that pig up
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #3 of 9 (permalink) Old 03-17-2011, 02:16 AM
Harl
Harl's Avatar
Send a message via AIM to Harl
Does it have any shaft play?? I no when one of my intake boots came off and I was getting on it she screamed like no other on mine.. So I pulled over to see what the crap was going on now.
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
post #4 of 9 (permalink) Old 03-17-2011, 02:20 AM
Your turbo is fubared.
Then again it might help if you had a sig so that we knew more about your truck and what mods.
02 f250
countryboyrob is offline
post #5 of 9 (permalink) Old 03-17-2011, 03:02 AM Thread Starter
mroutlawoffroad
There is no shaft play. I hope its something simple like a boot.
Im new to this site don't no how to set up a sig but truck has 6 pos custom tuned chip,AD injectors, and a hoodstack. Where is the best place to get a new compressor wheel?
post #6 of 9 (permalink) Old 03-17-2011, 03:04 AM
beans may have one
patrickke is offline
post #7 of 9 (permalink) Old 03-17-2011, 03:05 AM
just pop off the compressor housing and toss in a new wheel, will be a new truck again. hit up rons turbo shop, awsome to deal with!
post #8 of 9 (permalink) Old 03-17-2011, 03:11 AM Thread Starter
mroutlawoffroad
Thanks guys for the help
96 cclb 10" lift 38" tires.
6 pos custom tuned chip, AD injectors, hoodstack, fpr shim,isspro gauges, electric fans, Built trannismission.
OUTLAW OFFROAD traction bars.
post #9 of 9 (permalink) Old 03-17-2011, 03:12 AM
very easy to replace the wheel, BE CARFUL when tightening the new wheel, the rods strip out extremely easy. i had a junk turbo i was just messing with and did it by accident
