fuel regulator screen - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-16-2011, 06:53 AM Thread Starter
So I am reading here on DieselStop.com that you can easily clean the fuel regulator screen. Well I'm little confused, I'm not completely 100% the handy man and I don't need anything else screwed up on my truck...
The pictures they show are very rudementary... Anyone got any pictures/write-ups to better show this process?
tecster is offline
post #2 of 7 (permalink) Old 03-16-2011, 07:31 AM
Demon Dually
speeddemon31176's Avatar
Re: fuel regulator screen
OK on the driver side of the fuel bowl is the FPR. There are two 10mm bolts that secure it to the bowl. They are different lengths. Remove those two bolts and GENTLY pull the fpr away from the bowl. The screen is tiny and easily lost so pay attention. They can not be bought separately. Take a q-tip and clean both sides of the screen. If it has never been cleaned before you may need to remove it and while holding it tightly in your fingers spray it on both sides with carb cleaner or brake clean to clear any debris from the screen. Reassemble in reverse order.
speeddemon31176 is offline
post #3 of 7 (permalink) Old 03-16-2011, 07:54 AM Thread Starter
Hmmm...okay this should be fun.
tecster is offline
post #4 of 7 (permalink) Old 03-27-2011, 06:06 PM
kbmkviii's Avatar
should you drain the fuel bowl before doing this to not make a mess?
96- PIS 350 200s. 76mm Billett GT4202R. Big Oil. Twin E-Fuel.
BTS. Sump. 140v IDM. Melling. Fluidamper. H11. VS. PR.
Auto Meter- Boost, Pyro, HPOP, Trans, Fuel.
HPOP/coolant/trans filters.
6.0 I/C and Trans cooler.
2012 SRT8 300 6.4
kbmkviii is offline
post #5 of 7 (permalink) Old 03-27-2011, 06:10 PM
Yes.
02 f250
countryboyrob is offline
post #6 of 7 (permalink) Old 03-27-2011, 09:03 PM
Bugman's Avatar
Also stuff rags or towels around the filter housing so that when you drop something it doesn't end up under the housing.
Bugman is online now
post #7 of 7 (permalink) Old 03-28-2011, 11:14 PM
gnxtc2's Avatar
Don't drop the check ball. The screen is missing in the photo.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
