Factory Water Temp Gauge Stopped Working - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-16-2011, 04:01 AM Thread Starter
Did a quick search but found nothing on this. Where is the sending unit for the water temp gauge? Is there a way to check if it's functioning or is it cheep enough to just replace?
I hope this is a simple fix and not a cluster problem.
1997 F350 with a few mods and over 392,000 miles.
National Spring Leafs, E-Fuel, John Woods Transmission, Detroit Lockers Front & Rear, 4:56 Gears, Michelin XML Tires, Custom RSK...
Lots of pictures
lovesdunes is offline
post #2 of 7 (permalink) Old 03-16-2011, 04:03 AM
95powersmoker's Avatar
Re: Factory Water Temp Gauge Stopped Working
The sender is real inexpensive and just to the left of the Tstat IIRC.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 7 (permalink) Old 03-16-2011, 04:14 AM Thread Starter
Thanks
Lots of pictures
post #4 of 7 (permalink) Old 03-16-2011, 04:20 AM
Demon Dually
speeddemon31176's Avatar
As said it is right to the left of the pipe on the water pump and it cost 20 bucks to replace. Might want to check and see if it came unplugged or a wire is broke/damaged first.
speeddemon31176 is offline
post #5 of 7 (permalink) Old 03-16-2011, 04:22 AM
BUILT NOT BOUGHT!
GTOKILLER's Avatar
Same on a 00 PSD??? mine quite last week.
NOS is like a hot chick with STD's you know you wana hit it your just afraid of the consequences!!!
24" airbag lift, W/ digital air ride
20 x 14 Fuel Hostage, 46 x 19 x 20 Claws
4:88 gears
DPS chip, AEM CAI, 38r turbo
7" miter cut stack,
99 F 250 CC SB (orange) 4x4 PSD
99 F350 ECLB 4x4
00 F350 CCLB 4x4 PSD
2008 F350 CCLB 4x4 6.4 PSD
GTOKILLER is offline
post #6 of 7 (permalink) Old 03-16-2011, 04:25 AM
Demon Dually
Same exact sensor in the same exact spot.
post #7 of 7 (permalink) Old 03-16-2011, 06:29 PM
BUILT NOT BOUGHT!
GTOKILLER's Avatar
Cool thanks Ill fix it today!!
4:88 gears
7" miter cut stack,
99 F350 ECLB 4x4
