Coolant an water pump question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-16-2011, 12:01 AM Thread Starter
psdguy97
psdguy08's Avatar
Hey guys, my water pump is starting to leak and I need to swap it out. Are there any write ups on how to replace it? I've never changed one before. Also I want to switch to cat ECL coolant an all I can find is the 50/50 mix. Can I use this as long as I drain the block of all coolant? Thanks in advance.
Chris
95 F-250 ECLB
6637 air intake, 3 inch dp to 4 inch exhaust, EBPV delete, ccv mod, glowshift gauges ( fuel pressure, boost, trans temp, pyrometer ) Dp tuner ( no start, stock, 80hp econo, 60hp tow)
Cobra 29 classic w/nightwatch, Wilson 1000 magnet mount, weather guard backrack, code 3 lightbar.
psdguy08 is offline
post #2 of 4 (permalink) Old 03-16-2011, 01:48 AM Thread Starter
psdguy97
psdguy08's Avatar
Re: Coolant an water pump question
Anyone?
95 F-250 ECLB
psdguy08 is offline
post #3 of 4 (permalink) Old 03-16-2011, 03:51 AM
Demon Dually
speeddemon31176's Avatar
Fleetguard coolant from NAPA works just fine.
speeddemon31176 is offline
post #4 of 4 (permalink) Old 03-16-2011, 02:40 PM Thread Starter
psdguy97
psdguy08's Avatar
I'm a huge cat fan though. How much does the fleetgaurd run?
95 F-250 ECLB
psdguy08 is offline
