Timing cover question!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-15-2011, 12:15 AM Thread Starter
I did some research on cover differences and just have a question. I have a 95.5 block with a bad cover and a 97 motor in my truck with a major knock (Rod). I just wanna know if i take the 97 cover, hpop, front pump, pickup tube and bracket, swap the oil pans will it work? Thanks!
97 F-350 PSD 5-Speed Manual 2-Wheel Drive Crew Cab DRW. 6637 Filter, MBRP 3" DP to 4" stainless, CCV Mod, TS Chip, 2012 crew cab Seats, Converted flywheel and clutch
Chewii is offline
post #2 of 7 (permalink) Old 03-15-2011, 02:56 AM
Demon Dually
speeddemon31176's Avatar
Re: Timing cover question!!
Yes it will.
speeddemon31176 is offline
post #3 of 7 (permalink) Old 03-15-2011, 03:09 PM Thread Starter
Awsome! Any pointer on swapping these front covers? Does the lower oil pump have to be removed from the cover?
Chewii is offline
post #4 of 7 (permalink) Old 03-15-2011, 04:23 PM
I need a cover too, is yours cracked?
96 F-250 Ext Cab Long Bed.
02 Van Turbo, AB injectors, 140volt IDM, 4" TBE, BHAF, 17* HPOP, 5-Speed, electric fuel soon
White96Stroker is offline
post #5 of 7 (permalink) Old 03-15-2011, 09:23 PM Thread Starter
the 95 cover is cracked. Anyone on the oil pump?
Chewii is offline
post #6 of 7 (permalink) Old 03-20-2011, 02:56 AM
Terminator Nation
You will also need to use the 95 intakes unless you swap the heads, the 95s have 8 bolts and the 97s are 10 bolts. There also may be a difference in the drivers side exhaust manifolds. Use the 97s for you 97 truck.
old man dave is offline
post #7 of 7 (permalink) Old 04-07-2011, 12:54 AM Thread Starter
Thanks for the help! You were right on! Got the motor swapped and runs great! Just have to find the little oil leak I know have
Chewii is offline
