97 no start?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-14-2011, 11:21 PM Thread Starter
1st murdered 2011 psd
6L strokin's Avatar
Exclamation 97 no start??
one of my buddies just purchased a 97 7.3 with a little over 200K on it a few weeks ago. went out to start it up the other day and it turned over fine and was running but he noticed a CEL. he shut the truck down checked batteries fuses, etc. and went to restart and it will now only crank and wont turn over. he tried hooking up a buddy superchip to try to read codes but it gave an error message cant connect with pcm or something.
diesel tech said check the pcm power fuse, which was fine, he then said check to see if rpms are trying to move when cranking (if they dont might be cam sensor) which they do so now hes thinking something might be wrong with the pcm? any more input or if that might be the case any good places to buy one?
thanks!
2011 F250 6.7 CC SB FX4 tuxedo black, s&b intake, 5" flo pro, h&s xrt pro, tuned by SPE, diff lock override
2008 F250 6.4 CC SB 4x4 lariat dark stone, tuned by IDP
2003 F250 6.0 CC SB 4x4 lariat centinneal, too many mods! tuned by IDP
Shout outs to Innovative Diesel, Snyder Performance, Street Diesel, North Texas Diesel
6L strokin is offline
post #2 of 10 (permalink) Old 03-14-2011, 11:29 PM
Re: 97 no start??
Posting in the right section might get ya more help.
But my guess would be fuse #22 if thats good then I dont know.
02 f250
countryboyrob is offline
post #3 of 10 (permalink) Old 03-15-2011, 06:41 PM Thread Starter
6L strokin's Avatar
Re: 97 no start??
This is the right section.... All the fuses are not blown. Any helpful responses?
post #4 of 10 (permalink) Old 03-15-2011, 08:33 PM
Patrick Feeley's Avatar
Re: 97 no start??
Don't know how "helpful" these will be: Wait-to-Start light illuminating? How was it running when it was running? How's the oil level in the High Pressure Oil Pump resrvoir? How's the main oil level? Is the cigarette lighter fuse good? Check all the valvecover harness connections for evidence of melting or burning. Remove the oil cap and take a sniff ... smell like burned electrical insulation? Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #5 of 10 (permalink) Old 03-16-2011, 01:08 AM Thread Starter
6L strokin's Avatar
Re: 97 no start??
Pretty sure he told me the wait to start is not coming on...??
post #6 of 10 (permalink) Old 03-16-2011, 02:09 AM
95powersmoker's Avatar
Re: 97 no start??
Tell him to check all his fuses..
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #7 of 10 (permalink) Old 03-16-2011, 03:52 AM
Demon Dually
speeddemon31176's Avatar
Re: 97 no start??
Physically remove fuse 22 in the fuse box under the hood and test it for continuity. They can "look" fine and be bad.
speeddemon31176 is offline
post #8 of 10 (permalink) Old 03-16-2011, 02:29 PM
deezeljunky's Avatar
Re: 97 no start??
deezeljunky is offline
post #9 of 10 (permalink) Old 03-18-2011, 03:02 AM Thread Starter
6L strokin's Avatar
Re: 97 no start??
Not the fuse and he replaced some solenoid too still no start. Where is the PCM located on the truck? He is gonna pull it and get it checked out
post #10 of 10 (permalink) Old 03-18-2011, 03:12 AM
Smart A$$
MN_MountainMan's Avatar
Re: 97 no start??
Yeah, when mine did this it was the PCM. I got a refurbished one from some place in Florida for about $350 or so. It is in the firewall, behind the e-brake. Comes out from the engine side.
'97 F-350 CC 5-spd, Pyro, fuel and boost gauges, Banks intercooler, H2E turbo, Adrenaline HPOP, huge clutch, custom ADII regulated fuel system. Should be about 500 hp at the rear, don't know about torque. THIS IS MY BATTLE TANK- Project in Process
4XMayhem.com
MN_MountainMan is offline
