Welding on truck - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 03-14-2011, 06:10 PM Thread Starter
Moderator
PsRumors's Avatar
Welding on truck
I am in the process of installing an intercooler and for piece of mind I am going to weld in some more metal in a couple of places on the radiator support.
Are there any issues with welding like this? Problems with the ECM or sensors? Both batteries are disconnected. Just don't want to fry any of the electrical on the truck.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #2 of 21 (permalink) Old 03-14-2011, 06:13 PM
6.0h sh*t!
PowerSub's Avatar
Re: Welding on truck
As long as the batteries are disconnected you should be good.
PowerSub is offline
post #3 of 21 (permalink) Old 03-14-2011, 09:34 PM
I weld on everything with Batt connected..never a problem..
email:
Website:
OBSWIZ is offline
post #4 of 21 (permalink) Old 03-14-2011, 09:35 PM
Keep er shinny side up!
Never a problem yet...
abbottfarms is offline
post #5 of 21 (permalink) Old 03-14-2011, 09:46 PM Thread Starter
Moderator
PsRumors's Avatar
Good deal....thanks!
PsRumors is offline
post #6 of 21 (permalink) Old 03-14-2011, 10:37 PM
6.0h sh*t!
PowerSub's Avatar
Welded on a bus frame last year with batteries connected and took out 6 of the 9 ECM's in the thing. Oops! Very expensive screw up.
PowerSub is offline
post #7 of 21 (permalink) Old 03-14-2011, 11:34 PM
Monkeys have armpits!
Sprman's Avatar
we just got finished with one of the welders rigs here on the jobsite and we welded on it with everything connected. Done it multiple times on several vehicles with no issues.
2005 F-250 FX4 CC
bought it, then changed it.
Sprman is offline
post #8 of 21 (permalink) Old 03-14-2011, 11:59 PM
You can weld on a truck all day long and it won't hurt a thing.....IF....you remember to keep the ground close to your work and don't let any electronics get between the ground and the weld. The electricity travels in a straight line....or as straight as it can get. If you ground to the front bumper and weld on the back or vice versa, then you are asking for lots of trouble. The key is to keep the ground very close. I stretch trucks all the time with everything hooked up....no prob. My dump bed was built on my truck...no prob. I run a welding rig and weld on the tail all the time...again, no probs. It can be done and is done every day.
Diesel Avenger is offline
post #9 of 21 (permalink) Old 03-15-2011, 02:41 AM
Very true! Keep the ground on the same piece you are welding, if the ground must travel through a bolted joint there could be problems. Most of all, do not for any reason whatsoever weld on the engine with the ground attached to the frame, exhaust system, body, transmission, etc...every bearing in the engine will suffer arc damage.
LReiff is offline
post #10 of 21 (permalink) Old 03-15-2011, 02:44 AM
BUILT NOT BOUGHT!
GTOKILLER's Avatar
Same here, I always mean to disconnect but I always remember about the same time I finish up
NOS is like a hot chick with STD's you know you wana hit it your just afraid of the consequences!!!
24" airbag lift, W/ digital air ride
20 x 14 Fuel Hostage, 46 x 19 x 20 Claws
4:88 gears
DPS chip, AEM CAI, 38r turbo
7" miter cut stack,
99 F 250 CC SB (orange) 4x4 PSD
99 F350 ECLB 4x4
00 F350 CCLB 4x4 PSD
2008 F350 CCLB 4x4 6.4 PSD
GTOKILLER is offline
