10.25 and 10.50 Sterling - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-12-2011, 07:12 PM Thread Starter
I am searching for all information I can find on these rear ends. Does anyone know hao many different widths are available and what they came in. I have found that there are three generations of this. One post said that the gear set is interchangeable among all by using a different yoke ? I have found that the rotors are different from a srw to a drw and that brings the question of changing the caliper mount and rotor to change to drw. First, I WILL TRY TO DEAL WITH THE WIDTH and then address the other issues?? All info will be apreciated
Foxman
foxman is offline
post #2 of 8 (permalink) Old 03-12-2011, 07:14 PM
Bushwacker
chevyhurstolds84's Avatar
Send a message via AIM to chevyhurstolds84
Re: 10.25 and 10.50 Sterling
Foxman
you have disc brakes? what truck?
1996 DRW CCLB 2WD 5SPD 430k TOTALED
1984 Hurst/Olds 468 BBC e85 wheelies :)
1991 f150 RCSP 4.9 4x4 best beater in the world!
chevyhurstolds84 is offline
post #3 of 8 (permalink) Old 03-12-2011, 07:58 PM
STILL LEARNING
Bradbilt's Avatar
Foxman. I assume you are trying to put a 10.5 in a OBS?
Bradbilt is offline
post #4 of 8 (permalink) Old 03-12-2011, 10:02 PM Thread Starter
Very correct! I am trying to put a disc set up under a F350 cab and chassis. This is a 96 model and has the 34 inch wide frame rails. I am quite sure that moving the spring perches is going to be required. I would seriously like to put this together using off the shelf FORD original parts if possible. So far I have found that the rotors are diff from srw to drw. My truck is dual rear wheels and I have another about three inches on either side that I can bring the wheels out to the outside. Please share all ideas as Im really scrambling on this one. Thanks
Foxman
foxman is offline
post #5 of 8 (permalink) Old 03-12-2011, 10:16 PM
STILL LEARNING
Bradbilt's Avatar
How about you use a D80 from a 87-97 F-superduty , the bad part is you will have 10 lug rims
use a 99-up Cab and chassis 10.5 axle or maybe those are Dane 80s too, i know my 00 dually pickup was a D80, Either way you will have the 8 on 170mm bolt pattern though
Bradbilt is offline
post #6 of 8 (permalink) Old 03-13-2011, 06:17 AM
Demon Dually
speeddemon31176's Avatar
What about a Dana 70 drw out of a van? That would be the right width axle with drw and disc brakes. It would also have the 8x6.5 lug pattern. The perches might even be in the right location.
speeddemon31176 is offline
post #7 of 8 (permalink) Old 03-13-2011, 06:24 AM
nvme_63's Avatar
ha i worked at ford sterling axle where the axles are built you would think i would know the answer. i can find out monday for ya.
2005 F-350, cc sb, Lariat, Innovative Tunes, studs, EGR Delete, 64mm turbo, 225/100 cass injectors, reg return, air dog2, spray, 7 inch stacks, 18x9 Rockstars, 35 12.5 R18 nitto grapplers, XDI Intake, Auto Meter Ultra-Lite Gauges
nvme_63 is offline
post #8 of 8 (permalink) Old 03-13-2011, 06:52 AM
<<< Power
chvyrkr81's Avatar
I don't think you're gonna want a D70. Just go for the 80.
This is the first hook on this D70, the truck dyno'd 520 before some work was done to it that added a bit more. Probably gettin close to 550-575 in this vid.
06
02
97
74
chvyrkr81 is offline
