fuel filter swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-11-2011, 09:36 PM Thread Starter
fuel filter swap
So I just changed my fuel filter, installed me a Puralator filter with a new lid... I did it like the last one I changed, I unscrewed the lid...and to my surprise - the bowl was only about 1/4-1/2 way full...
Now the last time I swapped the filter - the fuel bowl was completely full. I have a good sized fuel leak but I thought I knew where it was coming from...I just don't know what to do now...
Any ideas?
tecster is offline
post #2 of 10 (permalink) Old 03-11-2011, 09:53 PM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
Re: fuel filter swap
was it that full with the filter out of it? thats about normal when you push the filter in is comes up to the top
Refugee
pstroke96 is offline
post #3 of 10 (permalink) Old 03-11-2011, 10:01 PM Thread Starter
it was at half when the filter was out, but the level didnt rise up when i was slipping the new filter in....
tecster is offline
post #4 of 10 (permalink) Old 03-11-2011, 10:04 PM
pstroke96's Avatar
well the new filter is dry its going to soak most of the fuel up. if your really worried, go unscrew it and see how full it is. if its around the same you should be fine
Refugee
post #5 of 10 (permalink) Old 03-12-2011, 07:18 AM
Demon Dually
speeddemon31176's Avatar
Run the truck for a few minutes then shut it off and check the bowl. Then wait a couple hours and without running the truck again check the bowl again. If it is staying full then you are fine. If it is low right after running it then your pump is weak. If it is full after running it and low a few hours later then you have a leak in the valley somewhere.
speeddemon31176 is offline
post #6 of 10 (permalink) Old 03-12-2011, 01:17 PM Thread Starter
Speed, I know I have a fuel leak in the valley, I believe its the plug (large bolt) on the rear of the pump(i think) which is located just below the turbo pedestal.
tecster is offline
post #7 of 10 (permalink) Old 03-12-2011, 05:52 PM
Demon Dually
Ah yes the infamous banjo bolt leak.
post #8 of 10 (permalink) Old 03-12-2011, 07:07 PM Thread Starter
Yeah? What's the fix, what size is that bolt? I leak alot though, is that known for that?
Fills the valley, leaks down the downpipe side.
tecster is offline
post #9 of 10 (permalink) Old 03-12-2011, 07:56 PM
Demon Dually
There are two metal crush washers that go in there. One between the bolt and the Y and one between the Y and the pump. Look in the library section for the parts list and you can get the part number for them. You will need a 1-1/4" angled boxed end wrench to do the job and a lot of patience.
post #10 of 10 (permalink) Old 03-12-2011, 08:32 PM Thread Starter
Mmm... patience? Where can I buy that tool!?
tecster is offline
