7.3 knock - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-11-2011, 07:03 PM Thread Starter
7.3 knock
I took the truck to my normal guy to put this thing back to stock and sell. he's the one who installed the parts so i got him to uninstall them. after getting the stock injectors put back in a contribution test showed #'s 4 and 8 were bad. figured things might work them selves out being there was only about 20 miles put on since replacement. well after 110 miles the truck was still missing and knocking and has a shutter feel with NO power. i reinstalled my stage ones and after 110 miles.. problem is still there. any ideas? thanks
95' F250 SCLB ZF5 4x4 4.10 white
Leveled, 33's, 325hp, smoked everything SOLD
97' f250 CCSB auto, 4x4, d60 swap, 4.10 white
4 or 6in lift?, 35x12.50 terra grapplers, tymar intake, straight pipe, cales tunes,
shiftracing17 is offline
post #2 of 8 (permalink) Old 03-11-2011, 07:25 PM
Black Stroker
whytry's Avatar
Re: 7.3 knock
What did he take off? Did he put new o rings and a copper washer in when doing the injectors?
Matts tunes
Exhaust
K&N
Nozzles
A1000 fuel system
whytry is offline
post #3 of 8 (permalink) Old 03-11-2011, 07:26 PM Thread Starter
Re: 7.3 knock
All new orings and coppers.
post #4 of 8 (permalink) Old 03-11-2011, 07:39 PM
Black Stroker
whytry's Avatar
Re: 7.3 knock
Did he take off the headstuds and springs ? Also did you check the injector cups? Did it throw any other codes?
Matts tunes
Exhaust
K&N
Nozzles
A1000 fuel system
whytry is offline
post #5 of 8 (permalink) Old 03-12-2011, 12:23 AM
04yfzkid's Avatar
Re: 7.3 knock
Have you ohm'd out the injector harness at all just to see if possibly something got screwed up on the reinstall?
04 cobra - MMR 5.0 stroker, 3.4 whipple, e-85, 30psi of boost when the belt doesn't slip
Currently converting to 78mm turbo.
96 f-250, diamond eye catless / mufflerless, DIY 6637, white rodgers 586-902, marinco mod, Denso High torque gear reduction starter, led door and dome lights, and PHP hydra for now.
04yfzkid is offline
post #6 of 8 (permalink) Old 03-12-2011, 05:22 PM Thread Starter
Re: 7.3 knock
Yes he took the studs out and pushrods. From what I saw the cups seemed to be fine. And no not yet about the harness. But I was wondering if they would make it do that.
post #7 of 8 (permalink) Old 03-12-2011, 05:56 PM
Demon Dually
speeddemon31176's Avatar
Re: 7.3 knock
Yep. Poor electrical connection to the injector could mean a non firing injector hence the miss.
speeddemon31176 is offline
post #8 of 8 (permalink) Old 03-19-2011, 05:17 PM Thread Starter
Re: 7.3 knock
Right well I meant to this extent. I figured if contribution tests and what not were being passed it couldn't be that. Hpop is good. Great icp and duty cycle. Fuel pressure is good. Brand new cps from ford. Only code being thrown is for exhaust back pressure.
