gauge install??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-10-2011, 10:23 PM Thread Starter
gauge install???
I have a 96 with a 7.3 and e4od. I'm lookin to install a boost,tranny temp,and exshaust temp gauge. Can anybody tell me the best places to install each guage for the best reading. Thanks for any and all input.
corbread is offline
post #2 of 4 (permalink) Old 03-10-2011, 11:11 PM
95powersmoker's Avatar
Re: gauge install???
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 4 (permalink) Old 03-11-2011, 12:34 AM
TBarrsTruck's Avatar
Boost in the Y pipe remove it then drill and tap, pyro in the collector or a manifold, same goes here. Trans temP into one of the pressure test ports, easiest one is right above the front driverside corner of the pan, simple remove the plug and insert your temp sender
'97 4x4 ECLB: SD IC, TW 4 pos, afe, 3-4" w/areoturbine, 4 gauge, DIY stage 1s, GTP38R, cust E-fuel, E-brake, stage3 CM meth, 439hp still trying for 600. cust stereo, highamp alt, cust paint
'78 F-150 RCLB: 460 swap, 3" lift, 33's,Trussed 9" w/ chrome-moly shafts, cust stereo, locked front/rear. My first love! EFI & Turbo coming soon...
TBarrsTruck is offline
post #4 of 4 (permalink) Old 03-11-2011, 06:27 AM
Learner
94strokeher's Avatar
I put my Pyro in the drivers side manifold, And my boost i taped into the map line with T fitting.
99 F250 Lariat 7.3 Auto, 6 inch Fabtech Lift, 35 KM2's, Straight pipe, 6637 intake.
94 Powerstroke, 3 inch lift, 3"DP 4" straight pipe 5" tip, Intake, Ts 6 position chip custom tunes. - SOLD
94strokeher is offline
