Hpop question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-10-2011, 04:45 PM Thread Starter
Goldknight's Avatar
Hpop question
Just put a 17 deg pump on my 96 that is totally rebuilt 0 miles on it. The 15 deg pump would not pump oil at all.
The question is once every thing is full should the heads hold that oil pressure for a bit after it pumps up?
I have to crank for 30 to 40 sec then the pressure pops up and it trys to fire but wont. As soon as i stop cranking the head pressure drops to 0 in 1 to 2 seconds. The gauge in on the pass head and I notice only the number 8 injector is pumping oil out when it trys to fire. I think i nerfed the injector orings on the other injectors.
Am i thinking about right? Getting tired of working on this truck
Goldknight is offline
post #2 of 7 (permalink) Old 03-10-2011, 05:45 PM
95powersmoker's Avatar
Re: Hpop question
It's going to take some cranking to get it to start...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 7 (permalink) Old 03-10-2011, 06:35 PM Thread Starter
Goldknight's Avatar
Re: Hpop question
I cranked it in burst for 5 min or so. Enough time to almost catch the starter on fire. man that stinks. I will need a new starter very soon. Going to pull the the from galley plugs on the heads and make sure there is no air in there when i get home.
post #4 of 7 (permalink) Old 03-10-2011, 06:46 PM
Re: Hpop question
Sounds like a possible injector O ring could be blown, or your IPR is stuck open. Check and make sure your IPR has voltage.
TerminatorEngineering is offline
post #5 of 7 (permalink) Old 03-11-2011, 05:34 PM Thread Starter
Goldknight's Avatar
Re: Hpop question
Pulled the font rail plugs on both head and added alot of oil to both sides. closed it up and pressure build much faster and then holds 300lb or so.
post #6 of 7 (permalink) Old 03-11-2011, 05:42 PM
Re: Hpop question
What year of truck?
If its a '95 the 17* won't work..only way is to have your 15* modded to a 17*. Thats free..PM me if I can help.
Cary
email:
Website:
OBSWIZ is offline
post #7 of 7 (permalink) Old 03-11-2011, 05:53 PM Thread Starter
Goldknight's Avatar
Re: Hpop question
the trucks a 96 the res is not draining
Thanks
