battery light? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 03-10-2011, 01:03 PM Thread Starter
deezeljunky's Avatar
battery light?
this just started happening yesterday but when i was driving home last night, i pulled in the drive and threw it in park and the battery warning light started flickering. I looked at the volts gauge and it was right in the middle where it always is. And today while sitting at a stop light the light started flickering again, and when i parkeed the truck and it was idling it came on but this time it was not flickering it just stayed on slolid, i reved it up and it went off and then came back on after i let it idle again. im thinking this s possibly the alternater going out or my batteries are bad, im not sure. An ideas? thanks!
deezeljunky is offline
post #2 of 17 (permalink) Old 03-10-2011, 01:06 PM
Twisted Addiction's Avatar
Re: battery light?
when ever the light is on its your alt
Fully built motor, Trans, 400/400, s480, gen3, decompressed, internally balanced, billet rods, mahile pistons, ported heads with valve work, o ringed heads, reg return, the works
Twisted Addiction is offline
post #3 of 17 (permalink) Old 03-10-2011, 01:25 PM
Black Stroker
whytry's Avatar
Re: battery light?
Agreed mine did the samething.
Matts tunes
Exhaust
K&N
Nozzles
A1000 fuel system
whytry is offline
post #4 of 17 (permalink) Old 03-10-2011, 02:03 PM
Re: battery light?
Agreed Alt, The slip rings on the rotor or more than like gone or close to it to where the brushes are not riding correctly, if you pull the regulator off you should see the problem. Replace the alt and your troubles will go away.
rake18 is offline
post #5 of 17 (permalink) Old 03-10-2011, 02:25 PM
wildstang3's Avatar
Re: battery light?
Dont go making that assumtion, here are two threads to read, I wouldn't change it. Test it with a volt ohm meter and make sure its putting out 12.5+ volts and if it is run it! Mine crapped out and I put a new one on and it does the same thing as yours is doing (been doing this for 6 months and never have starting or runability issues) read these two threads I posted about this known alternator problem!
!! battery light flashing off and on !!! - PowerStrokeNation
Battery light on dash flickering - PowerStrokeNation
wildstang3 is offline
post #6 of 17 (permalink) Old 03-10-2011, 02:32 PM
Simple is best
racefan68's Avatar
Re: battery light?
I had the exact same thing happen and it turned out to be my positive cable harness... the one that connects the 2 batteries and runs down to starter. I went through all the TS & that is what it ended up being. Alt. was putting out fine, put new cable ends on, all sorts of things before finally nailing down the cable harness. They are notorious for causing trouble. It is very likely the reason I went through several batteries as well.
97 HD Supercab LB 4x4. E4OD w/"mini shift kit" & Schaeffers synthetic, Tru Cool cooler, 4:10's, 33's on Weld Typhoon wheels, Gauges, Swamps stage 1's, Swamps IDM, TS 6 pos chip with Swamps tunes, Tymar intake, 3" DP, 4" exhaust (had to keep cat). Weather Guard toolbox, GPS, Billet grill.
racefan68 is offline
post #7 of 17 (permalink) Old 03-10-2011, 11:44 PM Thread Starter
Re: battery light?
Well dang, i had no clue this was big problem with the psd's. Im going to try messin with the connections and if that dosnt work then ill just go from there. Thanks for all the help!
post #8 of 17 (permalink) Old 03-11-2011, 03:50 AM
wildstang3's Avatar
Re: battery light?
You know racefan68 might be on to something I was under mine the other day and noticed I had some corrosion in a couple different spots on my cables, I guess I'll try changing it and see what happens!
post #9 of 17 (permalink) Old 03-11-2011, 04:08 AM
LiftedSuzuki's Avatar
Re: battery light?
Make sure the connector to your voltage regulator on the alternator isn't melted or screwed up like mine was. My light would flicker until I got out, jiggled the wires and then it would go away. Ended up the alternator was messed up internally as well so after a quick replacement I was on the road again (until the new one seized up 4 days later) lol
1995 F-250 7.3L 5 Speed, 4" Lift, 35" Toyos, Straight Pipe, DIY 6637 Intake, TS Chip with PHP Tunes, Glowshift Gauges
LiftedSuzuki is offline
post #10 of 17 (permalink) Old 03-11-2011, 06:00 AM
Re: battery light?
Also check the single blade plug on the top of the alternator. When this gets warn from engine vibration it will be a back connection and the Battery light will also come on. Use a little bit of dielectric grease and a pinch with pliers to crimp the female end of the plug for a snug fit...
cheers
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
