my truck loves diesel...too much! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 32 (permalink) Old 03-10-2011, 04:23 AM Thread Starter
Dieselnut7.3's Avatar
hey everyone my truck seems to love diesel fuel as much as i love my truck......i get about 125-150 miles to a tank (rear and mabe just 20 miles more on the front) in town and 200-225 on the highway....i want tohave a truck that get near 20 even high teens id be happy with but not this 10-12 mpg BS lol any thoughts as to what it could be..here is the specs on it and whats been done to her
286k mi
injectors have 175k
new fuel pump
fresh synthetic 5w40 rotella
lucas rear end oil
4:10's
new 5sp manual
9937 air filter mod
i know that having a dually that has 4:10's doesnt help but i still think it should be better......also granted i run waste trans/motor oil mixed with my fuel but the milage dont change weather its straight diesel or mixed any helpis much apprecieated and if you need any more info let me know!
THANKS!!
2003 F-250 6.0L 102kmi all stock except 4in cat back exhaust
(sold)1995 F-350 Dually 5sp 310k and counting. cold air intake, ts 6 position chip, Stage 1 injectors, 3in DP to 5in dual stacks.,
Dieselnut7.3 is offline
post #2 of 32 (permalink) Old 03-10-2011, 04:31 AM
It likes 4400 rpm!
Re: my truck loves diesel...too much!
Im in the same boat as you,
Im getting around 200-220 a tank and its like a 19 gallon tank thats not good at all, and 3.80 a gallon dont help either
1986-FORD F-250, 4X4, T-19,6.9 bored.020 MANY MODS, and broke again
1995-F-350, ext cab, DRW, 2WD, 291,xxx miles , ZF5, MODS:chopped exhuast, FPR shimmed, 6637, gutted ebpv
dyoung14 is offline
post #3 of 32 (permalink) Old 03-10-2011, 04:39 AM
00powersmoke's Avatar
Is it leaking on the ground behind you....? Thats bad.
00 f-250 Lariat 4x4,CC,SB
00powersmoke is offline
post #4 of 32 (permalink) Old 03-10-2011, 05:44 PM Thread Starter
no leaks.......and yea with diesel being at 3.95 a gallon its gettin pricey
post #5 of 32 (permalink) Old 03-10-2011, 05:46 PM
Daily Stroker
DieselFreak92's Avatar
Keep your foot out of it. I accelerated a lot slower off of stops on my last tank and got significantly more out of it then previous tanks. Also when cruising try to stay under or at 2000 rpm on the highway. Once you get passed 2k fuel mileage goes off the deep end. Your mileage should also improve this spring because not only will you be idling less (no more cold starts) but also the summer fuel gets better mileage.
1997
F250 Day Cab Long Bed 4x4 E4OD
- 04 axles - TS chip - diamond eye 5 inch - DIY intake -
- T500 - Stillwell built trans -
DieselFreak92 is offline
post #6 of 32 (permalink) Old 03-10-2011, 06:55 PM
It likes 4400 rpm!
I dont ever start mine in the cold and let it warm up,
i get in it crank it wait till it gets oil pressure then i go, i shift usually between-1500-2000 rpm never get over 2000rpm-55mph and no matter what i get right around 200 per tank even if i add a but load of power service to it no change,
If i drive it hard and shift between 2500-3000 and do 65+mph it still get around 180-200 per tank
dyoung14 is offline
post #7 of 32 (permalink) Old 03-10-2011, 07:46 PM
fwbkent's Avatar
My Jetta TDI hates the stuff. I can only get it to drink a gal. in 48 miles.
97 F350 crew cab 8' bed, 177,000 miles, bought new. Tymar intake,3 inch downpipe 4 in exhaust back , all SS, Cat gutted,
DPTunes F6 sweet change tunes via e-mail. Sonnax goodies Line pressure modulator valve, 1-2 2-3 3-4 accumulator control valves.
New trans BB FWB, Red Eagle and Z-Pak clutchs,triple disc converter. BUILT NOT BOUGHT
fwbkent is offline
post #8 of 32 (permalink) Old 03-10-2011, 08:18 PM
airman
redneckabbott's Avatar
You seem to be below average but that might be because of driving style. 200 seems to be average. That's what I usually get. I babied it like never before and went 235 miles and still had 1/4 tank when I filled up once. I'm thinking this summer will be a great time for someone to get a diesel relatively cheap! I think if someone doesn't need a diesel truck, they'll try to dump it off on someone else in a hurry!
Daryl Abbott
97 F350
redneckabbott is offline
post #9 of 32 (permalink) Old 03-11-2011, 12:08 AM
DIRT NASTY DIESEL!!
~NASTYSTROKER96~'s Avatar
i use about half of one tank when i go about 250 miles and im runnin 4.10s in mine. im runnin a superchip on mine and it seems to really help
Michael ~96 Ford F250~
Diamond eye exhaust, Autometer Ultralite gauges, Rough Country leveling kit, Superchip Programmer
~NASTYSTROKER96~ is offline
post #10 of 32 (permalink) Old 03-11-2011, 02:23 AM Thread Starter
i know going slower helps but keeping it under 2k rpm on highway for me would be going like 50 and id be run over my other crazy drivers.... i could take it a little more easier on the go pedal but even when i drove home to ny i stayed at 65mph about 2500 rpm and i still only got 12.6 mpg granted it needs new manifold gaskets but i cant imagine that it would affect it that much...i still get 16-18 psi of boost at WOT and the spec is min of 15 (alldata) well i can only hope that a chip and summer fuel will help this summer when i go home i guess!
