Where to start? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-06-2007, 03:16 AM Thread Starter
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Where to start?
I think I have some problems with my h2e. I shouldn't say just the h2e but with my set up. I just towed maybe 10k at the most 12k. I had to let out of it on almost every hill, oregon to nebraska I-80 90% of the way. I have tony's tow program, stg 1 and terminator. The most boost I saw was pushing 9lbs at 75mph. I'm running 35's with 3.55 gearing and have a 5spd. Any suggestions? What is a good course of action to finding the problem? 9lbs seems low on an 8% grade especially with no CAC? Having to slow down on the hills in Wyoming is a dangerous thing those big rigs haul as s. Thanks for any help.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #2 of 4 (permalink) Old 08-06-2007, 04:03 AM
OEM Moderator
Tom S's Avatar
Re: Where to start?
What is the most boost you can generate at 3000rpm?
Tom
Tom S is offline
post #3 of 4 (permalink) Old 08-06-2007, 04:20 AM Thread Starter
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Re: Where to start?
Under WOT the most I've seen is 30psi and then popped a boot. That was with exhaust leaks that I later fixed, or at least lessened. IIRC at 75, I'm around 2100-2200 rpms. One more thing, should my truck smoke once the turbo is lit with my set up working properly?
2005 F-250
post #4 of 4 (permalink) Old 08-06-2007, 11:30 PM
OEM Moderator
Tom S's Avatar
Re: Where to start?
The truck is not going to pull a hard hill at high speed at 2000 or 2100 rpm. That was the reason I asked how much boost you can make at 3000rpm. With you set up you should be down to just a haze at WOT with the turbo and motor wound up.
Try a grade at 2800+ rpm.
Tom
Tom S is offline
