1996 7.3L Check Engine Light - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-07-2008, 03:58 PM Thread Starter
I have a 1996 E-Super Duty with the 7.3L Powerstroke.
The engine starts and runs fine, although it is sluggish when cold and temperatures are around 32 degrees or below. However, if I attempt WOT at slow speeds, the CEL comes on and the engine won't rev up at all. I can barely get the truck to maintain 30 mph. The temporary fix is to shut the truck off and restart. After the restart, everything works fine until the CEL comes on again. I realise that I need to have the code read to get a real indication of what might be happening, but I was wondering is these symtoms sound familiar to anyone.
My other question is, will the ODBC II readers that are for sale on ebay generally read the codes from this truck?
Thanks
CrashOften is offline
post #2 of 10 (permalink) Old 02-07-2008, 04:03 PM
Re: 1996 7.3L Check Engine Light
yes the readers will read dtc and u might be having a fuel issue but reading the dtc would help pin point ur problem
00 f350 is offline
post #3 of 10 (permalink) Old 02-07-2008, 05:11 PM Thread Starter
Thanks. I think I'll order one - only $30 + ship.
I will post back in a few days when I get the codes.
post #4 of 10 (permalink) Old 02-07-2008, 05:14 PM
<----Colin Banks
mattymx's Avatar
WHere do you live? We have a help network and maybe someone near you has a code reader and can help you out.
https://powerstrokenation.com/forums/...splay.php?f=55
mattymx is offline
post #5 of 10 (permalink) Old 02-07-2008, 06:08 PM Thread Starter
I just updated my profile to include my location which is Mount Uniacke, Nova Scotia, Canada.
post #6 of 10 (permalink) Old 02-07-2008, 06:12 PM
<----Colin Banks
mattymx's Avatar
We have quite a few Canadian members here. Look through that list and see if there is anyone close.
mattymx is offline
post #7 of 10 (permalink) Old 02-07-2008, 06:17 PM Thread Starter
Thanks a lot for the help!
post #8 of 10 (permalink) Old 02-07-2008, 08:28 PM
racehauler's Avatar
The cheap code readers usually will not read codes on PSD's. If you are going to buy one make sure that it is capable of reading codes on Powerstroke diesels.
If you get a Superchips or Edge programer or something similar you can read codes with them. Sometimes people will sell them on ebay that are VIN locked so you can't use them for a power programer but they will still read codes.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #9 of 10 (permalink) Old 02-08-2008, 05:54 PM Thread Starter
I bought this one from ebay:
http://cgi.ebay.com/ebaymotors/OBD-2...mZ370019319470
Hopefully it will read the codes OK.
post #10 of 10 (permalink) Old 02-08-2008, 07:35 PM
racehauler's Avatar
Looks like they have an good return policy so you shouldn't loose to much if it won't work on your truck.
Let us know how it turns out that way we could reccomend this code reader to others if it works well on a PSD.
Eric
96 F-350 CC Dually
