OD Button - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-06-2008, 02:37 AM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
OD Button
Hey guys I think my OD button the shifter is being retarded. Tonight while I was hauling some cows to the sale barn, I noticed that the OD button would kick on and off. I would have to hold it for it to stay off. Another thing it would do is when I hit the brakes, it will come on and i can't switch it off. I dunno if it has anything with my chip or not? Thanks for any advice.
Reuben
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #2 of 9 (permalink) Old 02-06-2008, 03:20 AM
What else?
smokyred's Avatar
Re: OD Button
Pull your column plastic off, alot of times the wires wear through where they come out of the bottom of the shifter lever. If that's the case, you'll need a new shifter lever assembly.
Dave
smokyred is offline
post #3 of 9 (permalink) Old 02-06-2008, 04:15 AM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Re: OD Button
Allright will do thanks.
Reubine is offline
post #4 of 9 (permalink) Old 02-06-2008, 12:43 PM
racehauler's Avatar
Re: OD Button
Very common to have broken wires. New shifter should fix it.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #5 of 9 (permalink) Old 02-14-2008, 05:09 AM
Re: OD Button
Not a constant flash?
waxin is offline
post #6 of 9 (permalink) Old 02-14-2008, 12:34 PM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Re: OD Button
No its not a constant flash. Funny thing is it hasn't it done it since the night that I posted up.
Reubine is offline
post #7 of 9 (permalink) Old 02-24-2008, 02:29 PM
OBS junkie
Cat_Rebel's Avatar
Re: OD Button
Couldn't you undo the wiring from the button & make a seprate switch on the dash for your OD off switch?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 9 (permalink) Old 02-24-2008, 06:54 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: OD Button
thats what i did after mine broke off, but you only need a momentary switch
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #9 of 9 (permalink) Old 02-26-2008, 07:54 PM
OBS junkie
Cat_Rebel's Avatar
Re: OD Button
You have pics on how you did yours? Mine works now but down the road I'll probley just get a button or switch & mount it somewhere else like an older Dodge. With 31s & 4.10s I have to turn the OD off everytime I go into town or go on a bumpy dirt road. If your light on the throttle it will go into OD at 35mph & then come out as soon as you slow down for a light or if someone's turning & then go back into OD again as soon as your crusing about 35 or so. So I just turn it off & leave it off till I get out of town & can open it up to 45mph or more.
RIP Will Iott
