ext cab/sb on a std cab/lb frame? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-05-2008, 08:29 AM Thread Starter
urbanwheeler's Avatar
ok so i have done a ton of work to my truck and im getting tired of having a standard cab. im not going to buy a new truck and swap everything over, so i was wondering if anyone knew what the dimension differences were between a standard cab with a long bed and a extended cab with a short bed and if it would swap over. i would really like to put an extended cab on my frame.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #2 of 7 (permalink) Old 02-05-2008, 01:12 PM
racehauler's Avatar
Re: ext cab/sb on a std cab/lb frame?
The extended cab short bed is a longer wheel base. I don't know how much though. It could still be done, you will just have to shorten the bed.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 7 (permalink) Old 02-05-2008, 04:39 PM
Super cab swb is 139" wb. Super cab lwb is 155", cc swb is 152.2".
hope this helps urbanwheeler.
ono_55 is offline
post #4 of 7 (permalink) Old 02-05-2008, 05:46 PM
racehauler's Avatar
He needs to know what a standard cab LWB is also.
Eric
96 F-350 CC Dually
post #5 of 7 (permalink) Old 02-05-2008, 06:03 PM
Cute and cuddly boys!
mazdaparts's Avatar
Send a message via Yahoo to mazdaparts
IIRC the frames are made differently. The frame rails drop under the the passenger compartment and then raise under the bed. I'm not saying it can't be done but you may need some body lifting blocks.
2002 F250 Crewcab Shortbed 4X4 Totaled 6/16/12
2000 Expedition Eddie Bauer 4x4
There are 2 rules to getting ahead.
Rule #1. Don't tell anyone everything you know.
mazdaparts is offline
post #6 of 7 (permalink) Old 02-06-2008, 02:35 PM Thread Starter
ono 55 do you know how long a standard cab lwb is?
[SIGPIC][/SIGPIC]
post #7 of 7 (permalink) Old 02-06-2008, 03:05 PM
Standerd cab lwb is 133"
ono_55 is offline
