97 fuel lid problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-04-2008, 01:04 AM Thread Starter
Question 97 fuel lid problem
help! factory lid on my 7.3 amost twisted off (plastic & o.e) now I replaced the filter seal and it leaks. Is there a update or replacement for this
colliechaser is offline
post #2 of 6 (permalink) Old 02-04-2008, 02:32 AM
bigd4me2's Avatar
Re: 97 fuel lid problem
is the gasket square cut, or is it beveled? if its beveled it goes flat against the cap, bevel down at the bowl, or they leak. and yes, when they are upside down, you can twist the cap past the stopping point and cap will jump the threads and leak, i have done this once.
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #3 of 6 (permalink) Old 02-05-2008, 12:40 AM
Bugman's Avatar
If you need a new lid you can get it form here http://catalog.powerstrokeshop.com/p...&subcat2=86786 or I believe that NAPA also carrier aftermarket lids for the housing.
Jim
Bugman is offline
post #4 of 6 (permalink) Old 02-16-2008, 04:08 AM
Check Deiselsite. They have the baldwin with the built in cap. I have been happy for 50k miles (4 filters so far).
mtnwoody is offline
post #5 of 6 (permalink) Old 02-16-2008, 01:35 PM
Madvan's Avatar
Flat side on bowl with bevel facing up towards cap.
Lube with fuel.
Bill
97 Quigley 4X4 PSD
Madvan is offline
post #6 of 6 (permalink) Old 02-19-2008, 01:58 AM
Lube with fuel.
Bill
X 2 what said.
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
