no start issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-31-2008, 09:05 PM Thread Starter
<----Colin Banks
mattymx's Avatar
no start issues
Well this is weird. My truck ran perfectly one day a week ago and then I went to start it and nothing. It has been cold up here, down to 5* at night but never had a problem. The truck blows no smoke out of the tail pipe. All fuses are good and I swaped out my modded IDM for a stock 110V unit I have. Still nothing. I finally got my snap on scanner back and just did a buzz test. There were some slight pitch changes during the test, but all of them fired. Here is what the scanner showed after the buzz test.
P1219 %H (cid) low
P1273 cyl #3- high to low side open
P1274 cyl #4 high to low side open
P1276 cyl #6 high to low side open
P1278 cyl #8 high to low side open
P1298 IDM fault
P1293 high side open bank #1 right
P1294 high side open bank #2 left
There were no issues with the truck before it stopped working. No issues ever. I am going to install my modded IDM and see what it tests out at to see if the codes are the same. Thanks guys.
Matty
mattymx is offline
post #2 of 11 (permalink) Old 01-31-2008, 09:48 PM Thread Starter
<----Colin Banks
mattymx's Avatar
Re: no start issues
On edit----
The tach moves so the CPS is good. And I have this code as well. P0603 Internal Control Module KAM Error
mattymx is offline
post #3 of 11 (permalink) Old 01-31-2008, 10:02 PM
Re: no start issues
Matty, you have either bad IDM or bad UVH harness.
gregrob is offline
post #4 of 11 (permalink) Old 01-31-2008, 10:14 PM Thread Starter
<----Colin Banks
mattymx's Avatar
Re: no start issues
I just tested a core IDM I got from a guy a few months ago. I modded and ran it when I sent you mine. The day my truck stopped working, I inspected that IDM. It is one of the first generaation IDM100's. I unslodered my mod and looked around for issues. There seemed to be a little brown on some components on the other side of the mod. I installed a new resistor for my mod and sealed it back up. Still nothing. That was last week. I just tried to run the buzz test with that modded IDM and it did not buzz anything. So I guess I got a core from a guy that has failed, not related to the mod itself. I bought an IDM from a member here last week and that is the IDM that I ran the test on with the results shown in the first post. This IDM buzzes, but there are different pitches. I need another IDM to test more.
mattymx is offline
post #5 of 11 (permalink) Old 01-31-2008, 11:15 PM
Re: no start issues
My buddies should have gone out to you today. If you need to use it for a bit, or have me send yours just let me know.
gregrob is offline
post #6 of 11 (permalink) Old 01-31-2008, 11:28 PM Thread Starter
<----Colin Banks
mattymx's Avatar
Re: no start issues
My friend is coming over right now and I am going to try his IDM that I modded. I bet that is the issue. I am buying another IDM so I hope to be good if that is the issue.
mattymx is offline
post #7 of 11 (permalink) Old 02-01-2008, 01:03 AM Thread Starter
<----Colin Banks
mattymx's Avatar
Re: no start issues
WEll I just installed my friends IDM and it did not fire. The truck was plugged in for 2 hours and still nothing. I ran the buzz test with his IDM and it only came back with the IDM Fault code. No other codes came up.
mattymx is offline
post #8 of 11 (permalink) Old 02-01-2008, 02:37 AM
OEM Moderator
Tom S's Avatar
Re: no start issues
If you have the scan tool make sure you are building HP oil.
Tom
Tom S is offline
post #9 of 11 (permalink) Old 02-01-2008, 03:49 AM Thread Starter
<----Colin Banks
mattymx's Avatar
Re: no start issues
Tom
TOM YOU ARE THE MAN!!!!!!!!!!
I just went to scan for ICP and there was none. I unplugged the ICP and then plugged it back in. It fired right up. Dude... Thanks a million. I guess I need to look into that connection and the ICP sensor as well.
mattymx is offline
post #10 of 11 (permalink) Old 02-01-2008, 05:40 PM
mandkole's Avatar
Re: no start issues
Cool-- just an electrical snafu... I'm not certain that don't have something similiar. My truck will start perfectly 50 times, then on the 51st suddenly not start until after a key cycle or 2. Hot or cold, doesn't matter and no cels. I suspect its something like an ICP plug or sensor that acts up. It did it before and after the hpop/ipr changes. If I had an AE in those instances I could probably confirm it.
The only stuff in the HP oil, GP/inj, or IDM area that hasn't been changed, rebuilt or modded is the main harness and ICP sensor. I just haven't been jonesin to spend $350 on this stuff. Lots of electrical stuff on these rigs that can go wrong...
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
