Electric fuel pump relay control - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 04-24-2010, 01:49 AM Thread Starter
PSN nerd
GRRR im so Fin frustrated with controlling a electric pump. I have gone the oil pressure switch to control the relay and they would last a year or so and die, now I have gone to having it off the alternator and now I have had a string of alternator issues. My next thought is control the relay off the idm power, is there anybody else that has done this? it either that or i was thinking about swapping to a SD pcm just to have the pump control. I have had the last alternator last about a year and this one lasted 3 months. the one before that lasted like 6 or 7 years.
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #2 of 16 (permalink) Old 04-24-2010, 01:51 AM
Re: Electric fuel pump relay control
Use the red/light green from Fuse #22 that went to the fuel heater.
I don't even use a relay. I power the fuel pump directly from this wire.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #3 of 16 (permalink) Old 04-24-2010, 02:01 AM
OEM Moderator
Tom S's Avatar
I also control my relay off the old fuel heater circuit.
Tom S is offline
post #4 of 16 (permalink) Old 04-24-2010, 02:41 AM Thread Starter
PSN nerd
Sounds good I will have to get on that. I got time I bet its gonna be wedsday or thursday next week to get a replacement from DB
THANKS!!
JAKE is offline
post #5 of 16 (permalink) Old 04-24-2010, 11:45 PM
Demon Dually
speeddemon31176's Avatar
Just a thought here but if you are burning up relays and fuses and have to keep finding a new location to pull power from, YOU HAVE AN ELECTRICAL PROBLEM :) . Start looking over your wiring to your fuel pump for a short / open somewhere along the line. You shouldn't be having that many issues or issues at all if you have it wired up correctly.
speeddemon31176 is offline
post #6 of 16 (permalink) Old 04-25-2010, 04:37 PM
Good idea on the fuel heater for power supply. Iirc on my 96 I hooked directly from battery fused, the trigger was from key on only circut from fuse box inside cab. The ground wire I ran through Hobbs oil pressure switch set up on the oil filter auxilliary port. As I recall needed 2 psi oil pressure to trigger ground....
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37 Toyo R/Ts intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #7 of 16 (permalink) Old 04-26-2010, 06:48 AM
Terminator Nation
You should be drawing relay power only for control from alternator, heater or ignition switch run hot. I used ignition switch run hot myself without any problems.
The fuel pump power should be from battery/fuse/relay/fuel pump/ground. This should be your high current draw pump power circuit.
The relay power should be ignition run position hot/fuse/relay control/ (optional inertia switch)/oil switch ground/. Should be low current draw for your power sensing/relay control and presenting a low current load to the relay power source.
old man dave is offline
post #8 of 16 (permalink) Old 04-26-2010, 11:36 AM
Don't EFN worry about it
Aljay's Avatar
Main power from battery, trigger is from a key on source from under hood fuse panel.
Tuned by T Wildman
Aljay is offline
post #9 of 16 (permalink) Old 04-26-2010, 07:31 PM
You can also mod the underhood fuze box by adding a additional relay and using fuze #5 wire as a triger...works great and looke factory.
email:
Website:
OBSWIZ is offline
post #10 of 16 (permalink) Old 04-26-2010, 07:55 PM Thread Starter
PSN nerd
My relay is in the factory fuse box, I think there was something up with my alternator and it cooked the coil in the relay. I am going to power the relay coil off the fuel bowl fuse for now. The way its wired it looks very clean, the fuse is also in the factory box off of one of the empty spots I took advantage of.
JAKE is offline
