97 Powerstroke 10K Mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-22-2010, 07:03 AM Thread Starter
60POWERSTROKE73's Avatar
I heard about the 10K, 5.6K etc mods. I need some info on how this done. And if it's good to do. Thanks guys
2003 F-350 Powerstroke 6.0L CC LB Lariat FX4
MBRP 4" Turbo Back- Straight Pipe Glowshift Gauges- EGT, Boost, and Trans Temp SCT X3 with Custom Tunes from Innovative Diesel 21/2" Pro Comp Leveling Kit Moto Metal 951 rims on 33" Nitto Trail Grapplers
Originally Posted by bigrpowr View Post
The 6.4 is unreliable. You want a 03-04 6.0. Best motor ford ever built.
60POWERSTROKE73 is offline
post #2 of 4 (permalink) Old 04-22-2010, 01:01 PM
buckingbrutus's Avatar
Send a message via AIM to buckingbrutus
Re: 97 Powerstroke 10K Mod
It's placed in parrallel to another resistor inside your IDM, and its on the signal circuit to your injectors...Basically created less resistance for the signal to fire your injectors, so they open up a millisecond early or whatever the number is.
I've seen where some people hook it to a switch, and some put a rheostat on there for adjustability
1978 Bronco
7.3L PSD, Stage 2 DIY Injectors, ZF5, NP205, 1410 shafts, D60/14B, 9 inches of lift, 40x17 Ground hawgs
Airhorns, 12k winch, custom bumper
1995 F350 Dually daily driver with stage 2's,TW chip, dual stacks, and a Liftgate for all the random crap I find
buckingbrutus is offline
post #3 of 4 (permalink) Old 04-22-2010, 08:39 PM
Demon Dually
speeddemon31176's Avatar
The 10k mod doesn't go inside your IDM. It is place inline with the plug to the ICP sensor. Do a search on here for 10k mod and you will find tons of threads on the subject.
speeddemon31176 is offline
post #4 of 4 (permalink) Old 04-22-2010, 09:19 PM
thats the IDM mod.
10K mod is different.
02 f250
countryboyrob is offline
