I need a buzzer that wont drive me craaazy - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-26-2008, 06:33 PM Thread Starter
so i unhooked my buzzer. annoying. so i left my lights on. any way to remind me to shut my lights off without the stock buzzer? is there a dinger from another vehicle i could use that wont give me a headache?
kbud14 is offline
post #2 of 6 (permalink) Old 01-26-2008, 07:09 PM
Bugman's Avatar
Re: I need a buzzer that wont drive me craaazy
You can either put the buzzer back in and then disable the key chime witch is very simple or if you have done like a lot have and tried to see what was inside it with a hammer get one from just about any automotive store. It will hook into the fuse box on a circkit that works when the lights are on.
Jim
Bugman is offline
post #3 of 6 (permalink) Old 01-27-2008, 12:51 AM
OEM Moderator
Tom S's Avatar
I just disabled my key dinger and left the light dinger. I piece of tape over the brass strip on the ignition lock cylinder does the trick.
Tom
Tom S is offline
post #4 of 6 (permalink) Old 01-27-2008, 01:30 AM
Don't EFN worry about it
Aljay's Avatar
Tom
I did the same thing as tom but I was not so gentle when pulling my keyswitch out and reinstall now the thing only works if my headlights are left on.
Tuned by T Wildman
Aljay is offline
post #5 of 6 (permalink) Old 01-27-2008, 03:27 AM Thread Starter
OK! thanks ill try it. Pat on the back to those that got the Mellencamp referance.
kbud14 is offline
post #6 of 6 (permalink) Old 01-27-2008, 03:48 AM
crfracer's Avatar
I realize it isn't exactly what you were looking for in an answer, but I have just made it a habit to always try to push the light knob in, even during the day in the summer. I find that every once in awhile I will have turned them on and forgot, and since I to check every time that I turn the key off, it works. It also helps that I have never had the buzzer thingy.
1996 F-250
ext. cab, l/b, 4x4, john wood trans
, home built intake and 5" stack
, and more in the works
Go to:
for an up to date story on the build.
crfracer is offline
