I`m ordering a chips tomorrow and i have a question. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-18-2010, 11:03 PM Thread Starter
Do i need to pull my pcm and get the code off of it? Where is the code? And also do i have to drop the inner fender well to pull it out?? Thanks in advance Roger And i`m doing a diy idm mod i will let you know how it goes and the difference i notice.
96 f-250 5 speed, 4x4, 6637 intake, 3" down pipe to straight pipe, swamps tunes, Rosewood stage 1`s
village idiot is offline
post #2 of 7 (permalink) Old 04-18-2010, 11:25 PM
I know nothing...
joedaddy's Avatar
Re: I`m ordering a chips tomorrow and i have a question.
I just got though doing the TS Tony wildman chip in the Green Truck. I'll post all tonight. You will want to drop the inner fender, it will make things vastly easier. Also the code is on the passenger side of the PCM. You'll have to look very far over the fender to see it.
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #3 of 7 (permalink) Old 04-18-2010, 11:29 PM Thread Starter
So i do need to get the pcm code? How long does it take to pull the pcm out? Do i have to pull he pcm to get the code or is it on the part sticking out?
post #4 of 7 (permalink) Old 04-18-2010, 11:41 PM
I know nothing...
joedaddy's Avatar
TS Chip install - Powerstroke Nation
If you're getting it from Tony he didn't have to have my code. Here's a good link if you don't want to pull the PCM. I pulled mine because when I put this same chip into another truck last summer I F*#KED it all up by removing the silver from the contact points. Ues a scotch bright pad as TS recomends, it's better to not remove enough than to remove to much. And BTW the Green Truck is much more fun to drive now, I can't load the turbo and take off without smoking the tires in the top 2 positions Street/Strip & All Out.
joedaddy is offline
post #5 of 7 (permalink) Old 04-19-2010, 12:13 AM Thread Starter
Awesome I had one of tony`s chips a couple of years ago, but i forgot if he needed the pcm code or not. I also didn`t remember how long it took me to get the pcm out to put the chip on. Thanks for answering these questions, Roger
post #6 of 7 (permalink) Old 04-19-2010, 12:19 AM Thread Starter
Where exactly is the pcm code?
post #7 of 7 (permalink) Old 04-19-2010, 12:38 AM
On the PCM you may have to pull it. You dont have to have it to order a chip but i have seen some post where they did not include the PCM code and had some issues so i would make sure he has it.
2000 F350 CC SB Lariate
Afew exstras
All brought together by Tony Wildman
Dale
SZYD is offline
