fuel supply pump on 96 stroke {stupid question} - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 04-18-2010, 02:54 PM Thread Starter
strokefreak
strokefreak's Avatar
hey guys need some info. found two rubber lines on the top of the block leaking fuel a little. my repair book shows this to be the fuel supply pump and shows (barely) the two rubber lines coming off of it. but it does not give me any info as to where these lines go. i am going to try replacing these today but am curious about something first. can i just unbolt fuel filter bowl and move it out of the way to get to these two lines? or do i have to unbolt and move the turbo like the book suggests?
1996 Powerstroke. 159000 miles.
Custom F-250 Duallie Conversion.
Tymar - gauges - Swamps Tunes - MBRP Turbo back exh. Swamps HiFreq/HiVol IDM. Full Force Stage 1's. WW2. T500. SOLD.
2003 CCLB F-350
Current toy / exploder.
strokefreak is offline
post #2 of 16 (permalink) Old 04-18-2010, 03:54 PM
GilroyRacing's Avatar
Re: fuel supply pump on 96 stroke {stupid question}
You can unbolt the fuel bowl and get to them easier.
Replacement O-rings for Ford Diesel Engines
96FordF3507.3PSDCC, (Line X'd) bed, 4x4, 5 speed manual, 4.11 gears, 285/75/16 Cooper Discoverer ATP , 260,000 miles, 3-4" down pipe, 4" exhaust w/5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers, Garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
GilroyRacing is offline
post #3 of 16 (permalink) Old 04-18-2010, 03:57 PM
As the picture shows, just remove the Ypipe. You should be able to just unbolt the fuel bowl to give you some wiggle room without having to actually remove the bowl. Also, go to Napa and get a can of silicon spray and spray the inside the hose on the ends it will help them slide on a lot better.
post #4 of 16 (permalink) Old 04-18-2010, 05:07 PM Thread Starter
strokefreak
thank you very much sir! thats what i was hoping for,lol the easy way.
2003 CCLB F-350
post #5 of 16 (permalink) Old 04-18-2010, 05:57 PM
Ive had my fuel bowl out twice in the last couple weeks for fuel leaks, I feel your pain. haha
Good luck!
post #6 of 16 (permalink) Old 04-18-2010, 06:15 PM
Busted Knuckles
PSDEng's Avatar
You'd probably be better off just ditching the whole fuel bowl system and going with an electric set up!
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #7 of 16 (permalink) Old 04-18-2010, 06:19 PM
He can spend $20 to fix a couple hoses or spend $1,500 on an electric fuel setup....hmm wich makes more sence?
post #8 of 16 (permalink) Old 04-18-2010, 06:41 PM Thread Starter
strokefreak
yeah i tink ill stick with just replacing the hoses for now. thats a chunk of change i would rather throw in other areas first. thanx for the info tho guys. PS gilroyracing......THANX for posting the pic. that helped alot as to where those well hidden lines run.
2003 CCLB F-350
post #9 of 16 (permalink) Old 04-18-2010, 06:51 PM
No Problem, glad I could help.
post #10 of 16 (permalink) Old 04-18-2010, 10:28 PM
I did my electric fuel for less than 300. Just about every DIY e-fuel reported here has been less than $500.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
