Decceleration wobble - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-18-2010, 02:54 AM Thread Starter
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
Between the speed of 20-30 mph when I apply moderate-heavy pressure to the brakes I have been noticing a 'Death Wobble'.
Ive replaced the tie-rods, rebalanced the tires/wheels to the best they can get with military issued rubber, the steering box is new, and an adjustable panhard bar has been installed.
Ive been told by a mechanic who did the alignment, that it could be improperly worn rotors... however im not a rotor specialist sooo...
Btw, the shaking stops if I brake below 20mph or if I turn.
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #2 of 15 (permalink) Old 04-18-2010, 03:19 AM
Demon Dually
speeddemon31176's Avatar
Re: Decceleration wobble
Could be wheel bearings as well. i would jack up each side and shake the tire from 12 to 6 o'clock and then 3 to 9 o'clock and then 2 to 10 o'clock. first one is to check ball joints, second one is for steering, third is for wheel bearings. yes you will notice other problems during any of those positions but they will be more pronounced in those positions. You should also spin each tire whil it is jacked up and watch for it catching or wobbling indicating a warped rotor. Also you can set a block of wood next to the tire so that it just barely touches the tire and spin the tire and watch for side gaps/hitting of the tire. That could indicate a bad belt or deformed tire as well.
speeddemon31176 is offline
post #3 of 15 (permalink) Old 04-18-2010, 04:54 AM Thread Starter
Underfunded
moonshiner's Avatar
well I know one tire is out of round but its sitting on the rear to minimize the stabilization issue, planning on using some sort of dynamic balancing to cure that problem.
All of the bearings have been changed in the front. And this is a 1991 axle so it has kingpins, not sure what it feels like when those go bad...
2010 VW Jetta 2.5
post #4 of 15 (permalink) Old 04-18-2010, 09:40 AM
Demon Dually
A kingpin axle will do the same thing as a ball joint axle when they go bad. The difference between them is that a kingpin axle has a stud in the top and a tapered roller bearing in the bottom and no stud.
post #5 of 15 (permalink) Old 04-18-2010, 03:01 PM
oil burner
tughill283's Avatar
could be a tire with ripped cords.i had this problem once and the tire looked perfectly normal until i let the air out of it to change it,then a big bulge popped out.i would also think it could be the rotors.usually bad wheel bearings/king pin/ball joints will cause the death wobble at higher speeds in my experiences.
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #6 of 15 (permalink) Old 04-18-2010, 06:14 PM Thread Starter
Underfunded
moonshiner's Avatar
Its really weird. Ive noticed that since Ive tightened down my panhard bar more it has decreased. Sooo... I guessing it has to do with the front axle, and the tires that were out of round are sitting on the rear. One mechanic thinks something is wrong with the axle integrity, however this wobble problem started after I took off the tires designed for the highway and put on the military ones. Of course my kingpins could definitly be the issue afterall the axle is a 91'.
Whats the best way to check the kingpins?
2010 VW Jetta 2.5
post #7 of 15 (permalink) Old 04-18-2010, 06:22 PM
Demon Dually
You check kingpins the same way you check ball joints. An additional test method is with the wheel off the ground place a heavy bar under the tire in the center and lift up on it while feeling for clunking, movement in the joint. You answered your own question though already. The problem started when you switched tires. Put the good tires back on. If the problem goes away the military tires are junk.
post #8 of 15 (permalink) Old 04-18-2010, 06:28 PM Thread Starter
Underfunded
moonshiner's Avatar
Hahah, would love to put the procomp 35's back on however they have maybe 1/64" of tread an are currently being used on my buddies F250 that had tires showing the steel belts!
Oh well ill just replaced the kingpins later this summer when I get back from training. And the military tires may not balance well but they are soo inexpensive!! Love that!
Well back to finding more stuff to fix, thanks for the help
2010 VW Jetta 2.5
post #9 of 15 (permalink) Old 04-18-2010, 06:29 PM
OBS junkie
Cat_Rebel's Avatar
Warped rotors or a really out of balance tire.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #10 of 15 (permalink) Old 04-19-2010, 12:04 AM Thread Starter
Underfunded
moonshiner's Avatar
Why do you say warped rotors? ive been told that too, but im still not convinced.
2010 VW Jetta 2.5
