need help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-17-2010, 11:47 AM Thread Starter
learnin the hard way
97strkr's Avatar
need help
okay so about 3weeks ago my truck started acting up and i have no clue what it could be. I put a 3 in down pipe ts chip on it and a new south bend clutch about 2-3 months ago, its a 97 5 spd. okay so heres the problem when i accelerate it jumps up in rpms but doesnt move i would say there is a good 10- 15 second delay it is like the truck is in nuetral i thought it was the evbpbc the turbo would spool at the end of the gear (right as i needed to shift) so i wired that open to see if that would fix it and it didnt so any ideas on what this is? thanks
2006 F250 Lariat
EGR Delete
MRBP
Blue Spring
S&B Intake
CFM +
SCT
Autometer Factory Matched Guages
97strkr is offline
post #2 of 4 (permalink) Old 04-17-2010, 12:28 PM
Old guy from the old days
Believer45's Avatar
Re: need help
Manual transmission the only thing that would "not go" then "go" with no input from the driver other than pushing on the throttle pedal is a slipping clutch. Do you smell anything getting hot when this happens?
1995 F250 'Stroke 4x2 5 spd long bed, Edge Evolution CTR, homebuilt
, switched 10k, Putco Master Boss running boards, one off heavy duty
, 36" tall contractor cap, 287,000 miles.
for glow plug system help.
Believer45 is offline
post #3 of 4 (permalink) Old 04-17-2010, 01:51 PM
STILL LEARNING
Bradbilt's Avatar
Re: need help
I agree w the clutch. Did you do your break in?
Bradbilt is offline
post #4 of 4 (permalink) Old 04-17-2010, 02:10 PM Thread Starter
97strkr's Avatar
Re: need help
i dont smell anything and i did break it in
2006 F250 Lariat
EGR Delete
MRBP
Blue Spring
S&B Intake
CFM +
SCT
97strkr is offline
