bad 7.3 obs motor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-15-2010, 09:49 PM Thread Starter
powerstroke7396's Avatar
bad 7.3 obs motor
i sucked coolant into the motor,i dont know how it got in, the motor is out now i was going to replace the head gaskets and do head studs, anything to look for when i have it apart? motor has 170k on it anything i can do to build the motor up for under $2000 (rods,pistons)???
powerstroke7396 is offline
post #2 of 4 (permalink) Old 04-15-2010, 10:04 PM
Demon Dually
speeddemon31176's Avatar
Re: bad 7.3 obs motor
You better have the rods checked if it was running when it sucked the coolant in. Water does not compress and therefore you usually do serious damage when that happens. I would also say reseal the oil pan, new oil dipstick o-ring, new rear main seal and/or rear main seal plate reseal. Check the HPOP oil rail plugs at the back of the engine and replace o-rings as necessary. Front seal check/replacement along with new LPOP. Check your exhaust manifolds for leaks at the heads and have them machined if necessary. That stuff is just off the top of my head.
speeddemon31176 is offline
post #3 of 4 (permalink) Old 04-15-2010, 10:15 PM Thread Starter
yeah it was running when it happened it started pouring out the oil pan gasket is there a good place to get these gaskets (local dealership sucks)
post #4 of 4 (permalink) Old 04-15-2010, 10:23 PM
Demon Dually
International dealer. Same parts cheaper price usually.
