rear end ?97 4*4 3/4 ton - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-14-2010, 10:36 PM Thread Starter
i havent had this truck that long .got stuck the other day rear end wouldnt hook posi so i pulled the rear cover . well its not one . after cleaning the back cover really good its a 93 350 is what the cover says in junk yard yellow . the gears are 3. 55 s .how hard would it be to put a limited slip in this housing . ? or whats the best way to go about it .
97 f 250 4*4 auto 7.3 4 '' ,pipe , chipped,306,480 and counting
threestud is offline
post #2 of 8 (permalink) Old 04-15-2010, 12:28 AM
Re: rear end ?97 4*4 3/4 ton
personally if you havent done a R&P on an axle I wouldnt do it. I would just find another 10.25 rear axle with 3.55s that has a posi.
02 f250
countryboyrob is offline
post #3 of 8 (permalink) Old 04-15-2010, 01:00 AM Thread Starter
thanks. will do
post #4 of 8 (permalink) Old 04-15-2010, 01:02 AM
some may say that it isnt that hard to do but I know I will either find a different axle or have someone that has done it alot before I do it.
02 f250
post #5 of 8 (permalink) Old 04-15-2010, 01:17 AM
01 c/c sb 8 inch lift 39.5 swampers (ON THE ROAD AGAIN)
00 F450 (SOLD)
newest addition 06 F150 (STOCK)SSHHHHHH don't tell her its a work truck!
hold my beer & watch this sh1t!!
8inchstroker is offline
post #6 of 8 (permalink) Old 04-15-2010, 03:21 AM
Demon Dually
speeddemon31176's Avatar
I have done many differential setups in my time and I can tell you for sure that you don't want to attempt it without a laundry list of specialized tools that aren't cheap to buy. Things like pinion preload, pinion depth, gear mesh, side play, bearing removal/install which require a press and the right adapters. That is just off the top of my head.
speeddemon31176 is offline
post #7 of 8 (permalink) Old 04-15-2010, 03:28 AM Thread Starter
well i can do some things and other things are best left to others lol
thanks for replying you guys have helped me a lot with this truck ?????ss
and saved me a ton of money .
post #8 of 8 (permalink) Old 04-17-2010, 09:09 AM
Shortbus driver
u2slow's Avatar
Put in a Lockright. Cheaper, easier to install, and way more effective traction.
I had a limited slip in mine. Great for burnouts and sliding around in the rain. No better at preventing you from getting stuck. Also useless with some payload in the bed.
'93 F250 2wd, 7.3IDI/5spd/4.10
'89-93 Dodge CTD jalopies
u2slow is offline
