zf5 to zf6 convershion can it be done??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-14-2010, 08:17 PM Thread Starter
ETaylor0056's Avatar
Iv got a 96 f.250 4x4 7.3 with a zf5 that pops out of 4th gear every once and awhile and am scard is going to go out b4 to long. So iv been looking around trying to find a new tranny and found a sweet deal on a zf6 hooked up in a 2000 f.250 4x4 7.3l. Just woundering what could be done to fix my zf5 and how hard ift would be to convert my obs zf5 over to a zf6 speed? what all would you have to do???
1999 Ford F.250 4X4 Cortex
1976 Ford F.100 step-side 347 STROKER (Fast)
1963 Ford F.100 4X4 (ORIGINAL 223CI)
ETaylor0056 is offline
post #2 of 7 (permalink) Old 04-14-2010, 08:46 PM
The Fireman
big_stroker's Avatar
Re: zf5 to zf6 convershion can it be done???
It can be done but you will have to use the ZF6 Transfer case and you will need a new drive line and make some new cross brakets
big_stroker is offline
post #3 of 7 (permalink) Old 04-14-2010, 09:54 PM
I am in the middle of this very project, except I am converting from an auto. It has been pretty simple so far, I used all SD flywheel, clutch, engine plate. I took my drivelines in to get done today, so I sould have it wrapped up this weekend.
Sea97Stroker is offline
post #4 of 7 (permalink) Old 08-20-2010, 01:09 AM
bjc
i know this is an old thread, but am wondering what is the status of this "upgrade"?
just wondering what you did to the floor and shifter.
thanks.
bj
1997 F250 SCLB 4x4. 35" tires, ZF5/valair clutch, tymar intake, Diamond/Tymar 3/4" SS exhaust, all stock otherwise.
bjc is offline
post #5 of 7 (permalink) Old 08-21-2010, 03:13 AM
Ken Newman's Avatar
Im interested too. Did you have to do much to the foor?
'96 Crew cab
D-66
stage IIs
5 speed
RSK
Dana 60 front
Truetrac
4.10s
SD front springs
'53 C550 COE
4X4 F550 running gear
75 Early Bronco
zf 5 speed
injected 351
602-525-4474
Ken Newman is offline
post #6 of 7 (permalink) Old 08-22-2010, 09:33 PM
ZF6 Speed Swap into a 97 OBS - Page 2 - Powerstroke Nation
Details here...
post #7 of 7 (permalink) Old 08-24-2010, 12:20 AM
bjc
sweet!!! thanks.
bj
bjc is offline
