95 F350 add a leaf - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-14-2010, 03:27 AM Thread Starter
ianjadkins's Avatar
95 F350 add a leaf
I just want to get a few inches of lift on the front. I know all about the RSK and SD springs so please don't sugest that. I want to know if anyone has played with using a few leafs from rear packs in the front spring packs? I am not worried about a harsh ride as it is already bad anyways. What springs did you use and what would you recomend for 1-2 inches of lift? This is just for a while until I can afford to do it properly.
Thanks,
Ian
95 Extended cab Long Bed XLT
Dana 60
Tymar Intake
Sport Comp Gauges
FPR Shim
3" Dp - 4" Exhaust
ianjadkins is offline
post #2 of 5 (permalink) Old 04-14-2010, 01:22 PM
krazykustomz
pauljackmax610's Avatar
Re: 95 F350 add a leaf
i actually did a 2" add a leaf to my truck, i bought it at fat bobs garage.com, it leveled it good as for the ride, i couldnt tell a difference as my truck rides like a tank anyway
pauljackmax610 is offline
post #3 of 5 (permalink) Old 04-15-2010, 12:47 AM
What else?
smokyred's Avatar
Check to see if your leafspring bushings are worn out, replacing those will usually pick it up an inch or so. Otherwise, stick a set of add a leafs in the front.
Dave
smokyred is offline
post #4 of 5 (permalink) Old 04-15-2010, 01:23 AM Thread Starter
ianjadkins's Avatar
Bushings are fine. Springs are not negative arched. They are out of a 97 F350 and so is my dana 60. I just want to fit 35's without rubbing. Not cutting my bumper either. I am thinking of triying a few leafs from a rear pack.
Dana 60
Tymar Intake
Sport Comp Gauges
FPR Shim
3" Dp - 4" Exhaust
post #5 of 5 (permalink) Old 04-15-2010, 03:23 AM
Demon Dually
speeddemon31176's Avatar
You can shim your front bumper forward with washers but I don't think you will gain enough room to clear 35's without a bit more than an add a leaf.
speeddemon31176 is offline
