hpop reservoir - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-14-2010, 02:17 AM Thread Starter
hpop reservoir
I hear about the hpop reservoir and i`m curious how you check it and where should the oil level be? Do you check it where the allen headed plug is?? And where should the oil level be in there?
96 f-250 5 speed, 4x4, 6637 intake, 3" down pipe to straight pipe, swamps tunes, Rosewood stage 1`s
village idiot is offline
post #2 of 3 (permalink) Old 04-14-2010, 02:49 AM
I know nothing...
joedaddy's Avatar
Re: hpop reservoir
Mine is usually a 1/2 inch below the threads. If you're going to pull that plug clean the area with a wire brush or solvent, don't want any goober's getting in there.
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #3 of 3 (permalink) Old 04-14-2010, 03:34 AM
OEM Moderator
Tom S's Avatar
Re: hpop reservoir
If you are not having any issues there is no need to check the oil level in there FYI. Same oil that is in your oil pan.
Tom S is offline
