ECM question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-12-2010, 10:46 PM Thread Starter
Dieselholic
Wvdieseltech's Avatar
ECM question
I'm tired of fighting with the dealership to try and get my ECM reflashed so I can use the OBD2 plug and put a tuner on it. What numbers have to match up if I were to take an ECM out of 95 or 96?
94.5 F250 4x4 Manual, Tymar Intake, 3in downpipe, Glowshift Black 7 color Boost and Pyro.
Still on the list: Valiar Clutch, New or reflashed ECM, Stage 1's DIY's, and some sort of chip.
Wvdieseltech is offline
post #2 of 12 (permalink) Old 04-12-2010, 10:49 PM
Re: ECM question
why do you want it reflashed?
02 f250
countryboyrob is offline
post #3 of 12 (permalink) Old 04-12-2010, 10:51 PM
Demon Dually
speeddemon31176's Avatar
Re: ECM question
Rob he wants it flashed so that his OBD II port is functional. They are in the trucks in 94.5 but don't function unless you reflash the PCM. You could get a PCM out of any PSD that has a stick in it.
speeddemon31176 is offline
post #4 of 12 (permalink) Old 04-12-2010, 11:48 PM
Re: ECM question
ahhh ok. I so should have re-read the post lol
02 f250
post #5 of 12 (permalink) Old 04-13-2010, 02:10 AM Thread Starter
Dieselholic
Re: ECM question
so this one off of ebay "should" work http://cgi.ebay.com/ebaymotors/96-FO...item20afa8e1c7
post #6 of 12 (permalink) Old 04-13-2010, 03:54 AM
Demon Dually
Re: ECM question
As long as the PCM isn't a bad unit "DOA" then it will work just fine. Key things to remember are to first disconnect the batteries and second make sure the key is not in the ignition. I have found it easier to unbolt the harness plug and then remove the three nuts holding the e-brake assembly in place an remove the PCM that way. It avoids fighting with the inner fender.
post #7 of 12 (permalink) Old 04-13-2010, 07:18 AM
Terminator Nation
Re: ECM question
DPtuner can reflash the PCM for a reasonable cost, might give them a call.
old man dave is offline
post #8 of 12 (permalink) Old 04-13-2010, 03:58 PM
Re: ECM question
I'd take a DPTuner reflash over a trip to the Stealership any day.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #9 of 12 (permalink) Old 04-13-2010, 04:47 PM
Construction Babysitter
wooner's Avatar
Re: ECM question
Does it have to be a PCM out of an OBS, or can one out of a SD work too?
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
wooner is offline
post #10 of 12 (permalink) Old 04-13-2010, 05:02 PM
Re: ECM question
I'm no expert, but I'm pretty sure the SD wouldn't work...different pin configuration as well as different inputs/outputs (like the turbo wastegate, etc)
