engine weight? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-11-2010, 04:06 PM Thread Starter
Cratos's Avatar
engine weight?
what does a 7.3 weigh I am looking for a stand to build one on 1000 lb or 2000lb stand
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #2 of 15 (permalink) Old 04-11-2010, 04:11 PM
Re: engine weight?
I have read that it weighs in at 1000lbs but I believe that was with oil and everything else bolted up.
02 f250
countryboyrob is offline
post #3 of 15 (permalink) Old 04-11-2010, 04:26 PM
96strokerbp's Avatar
Re: engine weight?
I have heard a 1000 pounds as well.
96 f-350 7.3 RCLB
5 speed 175,000 miles, AFE Intake, 5 in. Straight Ts 6 pos chip wildman tuned, rds stage 2's, *17 hpop,38r turbo with wicked wheel
96strokerbp is offline
post #4 of 15 (permalink) Old 04-11-2010, 06:45 PM
Demon Dually
speeddemon31176's Avatar
Re: engine weight?
I would buy the heavier duty stand to be on the safe side. I wouldn't want that motor falling on my feet not to mention damaging the engine if the stand fails.
speeddemon31176 is offline
post #5 of 15 (permalink) Old 04-11-2010, 08:51 PM
Busted Knuckles
PSDEng's Avatar
Re: engine weight?
According to this months issue of diesel power mag. the 7.3 has an assembly weight of 920 or 980 lbs. I can't remember which one.
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #6 of 15 (permalink) Old 04-11-2010, 09:07 PM
Re: engine weight?
so about a 1,000lbs.... get the bigger engine stand.
post #7 of 15 (permalink) Old 04-11-2010, 10:38 PM
Demon Dually
Re: engine weight?
920 LBS is the assembled wieght so I would definitely go with the heavier duty stand.
post #8 of 15 (permalink) Old 04-11-2010, 11:30 PM
mwalsh9152's Avatar
Re: engine weight?
definitely get the heavier stand, and shop around for the heaviest looking one. Some of them are claimed to be 2,000, but look no different than the 1,000lb ones.
1995 7.3 Bronco
mwalsh9152 is offline
post #9 of 15 (permalink) Old 04-11-2010, 11:33 PM
HW
M4K3H808's Avatar
Send a message via AIM to M4K3H808
Re: engine weight?
rather be safe then sorry!
Ford Powerstroke 7.3l
K&N Intake
33x12.50 Mickey Thompson ATZ
6 speed manual transmission:
Hawaii born and raised
M4K3H808 is offline
post #10 of 15 (permalink) Old 04-12-2010, 03:46 PM Thread Starter
Cratos's Avatar
Re: engine weight?
yep thats what i was thinking too. anyone have likes / dis-likes with the stand thay have?
Cratos is offline
